urgent issue between core and Distribution
coolj_212
I configure ospf l3 between core switch and distribution and after 3 days I lose the connectivity between the core, Distribution and access switch after I restart the Distribution the network become normal the configuration that have been done as layer 3 is below and also I observe that one of the Distribution hang Also note that we did The below configuration in different 3 site and its working Find so please anyone have the same issue please advice
This configuration from core side
interface Port-channel44
 description connected to DIS- port-channel 44
 no switchport
 ip address 10.x.x.x 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
interface TenGigabitEthernet2/3/3
 description To | SWITCH |
 no switchport
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 channel-group 44 mode on
interface TenGigabitEthernet2/3/4
 no switchport
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
router ospf 1
router-id 2.2.2.2
 ispf
 log-adjacency-changes
 auto-cost reference-bandwidth 100000
 area 50 nssa
 redistribute connected subnets
network 10.x.x.x  0.0.0.0 area 50
This configuration from Distribution side
 description connected to port-channel 44
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip ospf 1 area 50
 bfd interval 750 min_rx 750 multiplier 3
interface TenGigabitEthernet1/2/3
 no switchport
 no ip address
interface TenGigabitEthernet2/2/3
 no switchport
 no ip address
router ospf 1
 router-id 5.5.5.5
 ispf
 area 50 nssa
distribution model: WS-C4507R+E
IOS:cat4500e-universalk9.SPA.03.05.00.E.152-1.E.bin
CORE MODEL: WS-C6506-E
CORE: s2t54-ipservicesk9-mz.SPA.122-50.SY.bin
23 Replies 23
I think the neighbour went down or had an issue due to poor link light levels.
You restarted the switch and it possibly brought the neighbour up for now but if the light levels are poor chances are it will happen again.
use un all command to disable debugging if you haven't done already :)
show command
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/2/4 25.8 74.0 70.0 0.0 -4.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/2/4 0.00 N/A N/A N/A N/A
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/2/4 -2.0 4.4 0.4 -8.2 -12.2
Receive Power Threshold Threshold Threshold Threshold
Te1/2/4 -2.6 4.4 0.4 -14.4 -18.4
DIS #show interfaces Ten 1/2/4 transceiver detail /2/4 transceiver detail 2/2/4 transceiver detail
Te2/2/4 25.6 74.0 70.0 0.0 -4.0
Te2/2/4 0.00 N/A N/A N/A N/A
Te2/2/4 -2.0 4.4 0.4 -8.2 -12.2
Te2/2/4 -2.0 4.4 0.4 -14.4 -18.4
DIS #show interfaces Ten 2/2/4 transceiver detail  transceiver detail 3 transceiver detail
Te2/2/3 26.8 74.0 70.0 0.0 -4.0
Te2/2/3 0.00 N/A N/A N/A N/A
Te2/2/3 -2.0 4.4 0.4 -8.2 -12.2
Te2/2/3 -2.6 4.4 0.4 -14.4 -18.4
The light levels look fine. Have you done anything?
Do you have an issue now or just being proactive to make sure everything is fine?
Please rate any helpful posts and Accept solutions :)
no I have-not done anything
Do you still have an issue?
Hello
what type of  hardware is this occurring on ?
are you running vss?
Kind Regards
Paul
yes am running vss
Hello
Can you post the outputs for the follwoing:
Show switch virtual
Show switch virtual role
Show switch virtual link
Show switch virtual port-channel
show switch module
Kind Regards
Paul
hello i configure the Distribution from L3 TO L2 and it was working Fine so configure it as L3 OSPF Between the cor and Distribution so its work for 3 days Fine and there is vss between Dis 1 and Dis 2 after 3 days the I lose the ospf between the core Dis I went to chick from the Dis Site I found the VSS is not working
VSSDS-# show switch virtual role
xecuting the command on VSS member switch role = VSS Active, id = 1
RRP information for Instance 1
Valid Flags   Peer     Preferred Reserved
               Count     Peer       Peer
TRUE   V       0           0          0
Switch Switch Status Preempt       Priority Role     Local   Remote
Number         Oper(Conf)   Oper(Conf)         SID     SID
LOCAL   1     UP     FALSE(N )   100(100) ACTIVE   0       0
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
I in L2 and it was working for more
Switch mode                  : Virtual Switch
Virtual switch domain number : 2
Local switch number         : 1
Local switch operational role: Virtual Switch Active
Cannot execute command on peer supervisor because it is not in SSO Standby state
VSSDS-# show switch virtual link
Executing the command on VSS member switch role = VSS Active, id = 1
VSL Status : DOWN
VSL Uptime : -
VSL Control Link : -
VSL Encryption : Configured Mode - Off, Operational Mode - Off
And also in the LOG I found this output
*Sep 26 04:28:04.428: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Sep 26 04:28:06.025: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
*Sep 26 04:31:49.463: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Sep 26 04:31:50.894: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
*Sep 27 21:42:17.243: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
Pool: I/O Free: 9096 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Spanning Tree", ipl= 0, pid= 201
-Traceback= 1#49176b00b95a50f3145e3825de17d470 :1F6A5000+2CFD660 :1F6A5000+2CFDA24 :1F6A5000+4160EA0 :1F6A5000+4168078 :1F6A5000+16F0E3C :1F6A5000+16EFE7C :1F6A5000+16EB6CC :1F6A5000+3F97448 :1F6A5000+3F97BF8 :1F6A5000+3F61CC4
*Sep 27 21:42:47.314: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:43:17.384: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:43:47.398: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
-Process= "Pool Manager", ipl= 0, pid= 8
-Traceback= 1#49176b00b95a50f3145e3825de17d470 :1F6A5000+2CFD660 :1F6A5000+2CFDA24 :1F6A5000+4160EA0 :1F6A5000+4168078 :1F6A5000+16F0E3C :1F6A5000+4182EC8 :1F6A5000+41830A8
*Sep 27 21:44:17.406: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:44:47.459: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:45:17.475: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:45:47.487: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:46:17.519: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:46:47.559: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:47:17.583: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:47:47.595: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:48:17.599: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:48:47.612: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:49:17.619: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:49:47.647: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:50:17.703: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:50:47.712: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:51:17.747: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
*Sep 27 21:51:47.778: %SYS-2-MALLOCFAIL: Memory allocation of 276 bytes failed from 0x20D95E38, alignment 8
-Process= "Pool Manager", ipl= 0, pid= 8’
When I restart the Distribution every think work Fine can you Please Advise
