Replace Supervisor Slot At Cisco Catalyst 4510R+E Switch
magdy fekry
I Must power off core switch 4510R+E when replace Supervisor slot ? or its normal during system on  ?
Leo Laohoo
If the chassis only have a single supervisor card, powering down is necessary.
If the chassis is dual-supervisor card, then it is not necessary.  Just make sure the new/replacement supervisor card is running the same IOS version as the active one.
IMPORTANT:  Whether it is a single or dual-supervisor card, it is good practice to connect a console cable to the to the new/replacement line card and record the boot-up process in case troubleshooting is required.
balaji.bandi
 Hot-swappable components in the 4500 : Supervisor, line cards, power supplies, and fan tray are hot-swappable
http://www.cisco.com/en/US/products/hw/switches/ps4324/
But best practice is to take back up, and do the change in change window. if any unforeseen may cause service interruption.
BB
Leo Laohoo
