usb ports on 6509 supervisors
carl_townshend
Hi all
Can anyone tell me what the usb ports are used for on the supervisor cards?
I want to back up my file system, can I use a USB stick in the USB port to do this ? or are they for console use ?
cheers
Carl
So if I insert a usb stick I can save the config to it ?
cheers
Carl
What type of Sup do you have?  The USB port does not work on Sup-720-VS
Carl,
USB will never be supported on Sup32 and Sup720.  USB support starts fro Sup2T.
NOTE:  Don't a$k why.  You don't want to know.
The other way to save the config is to use Cisco or supported third-party CF.
