USE Cisco catalyst c9500-48Y4C-A without DNA center
MKH
Hello
Because of the EOL announcement of catalyst 4500X switch, we want to replace it  with C9500-48Y4C-A in the our new LOM.
I have configured below LOM in the cisco build and price portal:
C9500-48Y4C-ACatalyst 9500 48-port x 1/10/25G + 4-port 40/100G, Advantage1
SC9500HUK9-1612Cisco Catalyst 9500H XE.16.12 UNIVERSAL  1
C9K-PWR-650WAC-R650W AC Config 4 Power Supply front to back cooling  1
C9K-PWR-650WAC-R/2650W AC Config 4 Power Supply front to back cooling  1
CAB-C13-CBNCabinet Jumper Power Cord, 250 VAC 10A, C14-C13 Connectors  2
C9500-DNA-48Y4C-AC9500 DNA Advantage, Term License1
C9500-DNA-A-3YCisco Catalyst 9500 DNA Advantage 3 Year License1
PI-LFAS-AP-T-3YPI Dev Lic for Lifecycle & Assurance Term 3Y  3
We just want to use VSS and some simple routing  features.
Can I use this switch without DNA center for above features?
Do the selected license support VSS?
Thank you
5 Replies 5
balaji.bandi
yes, you can set up without DNAC, VSS = Stackwise virtual now.
Look at the license requirement for theStackwise Virtual.
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.pdf
BB
Leo Laohoo
Where's your Maintenance? Particularly the part where it will allow download of software?
Hello
I can download software, but I don't want to download it. I don't want to upgrade the old switch.
I need some ordinary L2 and L3 switching and routing in our LAN (For end user) and I want to buy this switch. I don't need DNA center features.
I need to be sure, VSS and ordinary R&S features that supported in 4500X are possible in c9500-48Y4C-A without DNA center.
Thank you.
I hate to be the one to break it to you:  The switch is going to be loaded with 16.12.1 (when you get it).  You will want to upgrade/downgrade the firmware.  Soon.
Have a look at CSCvr86782.
pheger
NBAR
Full Netflow
ERSPAN
Wireshark
EEM
Bonjour
If you use any of these technologies, you are required to continuously invest and renew your DNA licenses
DNA licenses are not strictly tied to DNA-related features, but limit usage of switch-features under a perpetual license as well.
https://www.cisco.com/c/m/en_us/products/software/dna-subscription-switching/en-sw-sub-matrix-switching.html?OID=otren019471
