Usernames and password
Hi.
show running-config show me
username XXX privilege 15 secret xxx
username YYY privilege 10 secret xxx
username ZZZ privilege 10 password xxx
line con 0
password 7 xxxxx
login
line aux 0
line vty 0 4
password 7 xxxx
login local
how can i do to configure?
wong34539
Level 6
Level 6
From the running-config, I found that you have 3 users - one (xxx) and privilege level 15 and other two at privilege level 10.
If you are logging as a user with privilege level 10, then you might be able to configure some features in the device. If you are logging as a user with privilege level 15 (highest), then you must be able to configure the device. To understand more on the privilege levels, refer to http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00803f3bb7.html.
