01-21-2008 03:22 PM - edited 03-05-2019 08:36 PM
Thanks for reading my post. I'm new to Cisco admin'ing and need some help. We currently have a T1 that comes into our offices for servers and an internet connection. Its running off a 4000 cisco series as the outside router and then a 4500 series connects that to handle the "division of labor" for our servers. We currently use a Linksys WRT54GL upgraded to DD-WRT firmware for our NAT router.
I've been asked to configure a spare 2621 to handle the job instead. It will be on the same /24 as one of our networks doing this job. I will post the configuration at the end of thise for comments/clarification. Basically, I have this router sitting on the <<masked by moderator>>0/24 network with the <<masked by moderator>>10 ip address on fastEth0. The fastEth0/1 is on our internal network, 192.168.254.0/24. We are using static routes for routing. This router will eventually be a DHCP server for our internal network, but thats another project for another day.
version 12.1
service timestamps debug uptime
service timestamps log uptime
no service dhcp
hostname kyNatRouter
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxx1
ip subnet-zero
no ip source-route
ip domain-name car-part.com
ip name-server <<masked by moderator>>
interface Null0
no ip unreachables
interface FastEthernet0/0
ip address <<masked by moderator>>10 255.255.255.0
ip nat outside
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Serial0/0
bandwidth 1536
no ip address
encapsulation frame-relay IETF
shutdown
no fair-queue
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
bandwidth 1536
shutdown
no cdp enable
frame-relay interface-dlci 500 IETF
interface FastEthernet0/1
ip address 192.168.254.1 255.255.255.0
ip access-group in_to_out in
ip nat inside
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Serial0/1
no ip address
shutdown
no cdp enable
ip nat inside source static tcp <<masked by moderator>>10 21 192.168.254.232 21 extendable
ip nat inside source static tcp <<masked by moderator>>10 2110 192.168.254.67 2110 extendable
ip nat inside source static tcp <<masked by moderator>>10 80 192.168.254.68 80 extendable
ip nat inside source static tcp <<masked by moderator>>10 5942 192.168.254.6 5942 extendable
ip nat inside source static tcp <<masked by moderator>>10 2098 192.168.254.120 2098 extendable
ip nat inside source static tcp <<masked by moderator>>10 2097 192.168.254.120 2097 extendable
ip nat inside source static tcp <<masked by moderator>>10 2096 192.168.254.120 2096 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 <<masked by moderator>>1
ip route <<masked by moderator>>0 255.255.255.0 <<masked by moderator>>1
no ip http server
ip access-list extended in_to_out
permit ip any 192.168.254.0 0.0.0.255
logging facility local4
logging 192.168.104.254
access-list 1 permit 0.0.0.0 255.255.255.0
no cdp run
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password !firststep
login
transport input none
scheduler allocate 4000 1000
end
01-21-2008 03:51 PM
1)
ip nat inside source static should have the internal IP address first and the external IP address second. For instance:
ip nat inside source static tcp 22.22.22.10 21 192.168.254.232 21 extendable
should be:
ip nat inside source static tcp 192.168.254.232 21 22.22.22.10 21 extendable
2) Your ACL
has no merit, what's the point of it?
The rest looks fine.
HTH,
__
Edison.
