Using a GLC-T with a Nexus 3548
Andrew Cormier
I am sorry I didnt get the exact message but I am hoping someone can help.
We have two nexus 3548s we are deploying and have 4 GLC-T  SFPs
I plugged them in to ports Eth1/1 and Eth1/2 on both switches.
When the links didnt come up I did a sho int status and I dont remember exactly what it said but it was something like
sfpUnsupported or sfpInvalid or sfpUnknow. I dont remember the exact term.
Any thoughts?
I thought I would see the errors in the logs but alas.. no.
5 Replies 5
acampbell
Looking at this link:-
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/hw/installation/guide/nexus3000_hardware_install_guide_book/overview.html#wp1083050
The GLC-T is supported on your 3548 - Are your GLC-T genuine cisco parts
Alex
Regards, Alex. Please rate useful posts.
They are supposed to be genuine cisco parts.
Bought from a certified cisco reseller.. they are labled cisco parts
PN 30.-1410-03
each has a unique SN and QR code
FIXED! Sho int statu was saying sfpInvali
When I changed the port speed to 1000 it connected properly. Good to know lol :)
Reza Sharifi
As Alex also noted, you usally get that message when you purchase the optics from a none Cisco certified parter/reseler or from Cisco directly.  It also may help if you set the speed under these interfaces.
pradeepser
Configure the interface speed to 1000 on Eth1/1 and Eth1/2 and it should resolve the issue.
Pradeep
