using BGP
kaustubhchavan
if i am using bgp connected to 2 isp 1 isp is having better path but low bandwidth & another one having better bandwidth logest path compare with another which one will it chooses ?
Harold Ritter
Kaustubh,
BGP doesn't take the bandwidth into consideration. The path having been selected by the BGP best path selection process will be usede even if the next hop is reachable via a lower speed link.
sonyscaria
Use
set as-path prepend
for the isp with low bandwidth. So the then shortest as-path ( better bandwidth ) link is preferred than other
regards
sony
