Using Catalyst 3560 for Load Balancing
members1st
Community Member
Is it possible using Catalyst 3560 as load balancing? FW > Catalyst 3560 > Web Server. I have never using any switch for the load balancing and have no experience at all for this usage.
Can anyone help on this subject?
Thanks.
Jerry Ye
Hi Nelson,
The 3560 doesn't support load balancing including destination NAT (it doesn't support any kind of NAT) or SLB.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html
HTH,
jerry
Which switch will support load balancing?
The IP SLB feature has been removed from the IOS. The hardware platform for SLB is the ACE appliance. The only Catalyst platform that supports NAT is the C6500.
jerry
