Using default routes learned from OSPF via adjacent switches or own switch def routes
getaway51
Level 2
Level 2
Hi ,
Both my core switches has default routes going to routers. How can I check if the core switches is using its own default route or def route OSPF learned from adjacent core switches?
5 Replies 5
CHYMER
Hi mr,
You should use command below
Show ip route 0.0.0.0/0
If it is static route => route 0.0.0.0/0 is owner of this core switch
if it is route learn via ospf => check next hop and you will know default route learn from (maybe learn from router of other core switch) ?
Thanks and Brgs,
Seb Rupik
Hi there,
If the 'own switch default route' is a statically configured route defined by specifying a next-hop IP (instead of just an exit interface) then providing the next-hop is reachable via an interface which is up/up, then the static route would be visible in the routing table~:
sh ip route static
A route learned via OSPF would be displayed with the command:
sh ip route ospf
If both routes were valid, then keep in mind that the static route would have a lower Administrative Distance than the OSPF route. Therefore the static route would always take precedence over the OSPF route.
cheers,
Seb.
Hello
The core switches will use their own defaults and not the advertised ospf ones due to the lower administrative distance value of the core switches defaults.
Kind Regards
Paul
Can I see the "lower administrative distance value" when i saw ip route 0.0.0.0/0?
Does this means i will see two def route 0.0.0.0/0, each with different preference?
show ip route
will give output like:
S*     0.0.0.0/0 [1/0] via 192.168.1.1
The element [1/0]   indicates an AD of 1 and a metric of 0
Only the route with the lowest AD will be installed in the routing table.
cheers,
Seb.
