VLANS across multiple switches
14101R14944A
Hi there, please move if in wrong forum
I have a single switch (Switch1 10.10.6.10) with three VLANS (VLAN200, VLAN300 and VLAN400)
I want to add two switches for more ports (Switch2 10.10.6.20 and Switch3 10.10.6.30) so all three switches have all three VLANS.
What are the commands I need to add to each switch to do this?
I have seen several examples on this forum, but not sure of the correct syntax
Thanks!
Hello
I assume your switch 1 is the L3 switch performing the inter-vlan routing as such below is a basic config to the successful connection
Switch1
int x/x
description link to switch 2
switchport mode trunk
no shut
exit
int x/x
description link to switch 3
no shut
exit
Switch2
int vlan 200
Description MGT ip address for switch
ip address 10.10.6.20 255.255.255.0
no shut
no ip routing
ip default-gateway 10.10.6.10
int x/x
description link to switch 1
no shut
exit
vlan 200,300,400
exit
int x/x
description access-port for vlan 200
switchport host
switchport access vlan 200
no shut
exit
int x/x
description access-port for vlan 300
switchport host
switchport access vlan 300
no shut
exit
etc....
Switch3
int vlan 200
ip address 10.10.6.30 255.255.255.0
no shut
no ip routing
int x/x
no shut
exit
vlan 200,300,400
exit
int x/x
switchport host
no shut
exit
int x/x
switchport host
no shut
exit
etc....
Kind Regards
Paul
luis_cordova
Hi @14101R14944A ,
The links that connect the switches must be configured in trunk mode:
S(config)# interface f0/x
S(config-if)# switchport mode trunk
To create the vlan:
S(config)#  vlan 200
S(config-vlan)# name <vlan name>
Hello
Switch1
int x/x
no shut
exit
int x/x
no shut
exit
Switch2
int vlan 200
no shut
no ip routing
int x/x
no shut
exit
vlan 200,300,400
exit
int x/x
switchport host
no shut
exit
int x/x
switchport host
no shut
exit
etc....
Switch3
int vlan 200
no shut
no ip routing
int x/x
no shut
exit
vlan 200,300,400
exit
int x/x
switchport host
no shut
exit
int x/x
switchport host
no shut
exit
etc....
Kind Regards
Paul
Thank you Paul!
