Software packages for C6800-SUP6T
Madura Malwatte
Level 4
Level 4
C6807-XL-S6T-BUN comes with IP Services, there is an option to upgrade to Advanced Enterprise software package. But I cannot find details of what features are included in the Advanced Enterprise package that is not available in IP Services.
I found documentation for the 6500, but nothing for the C6800-SUP6T. Can someone help provide the specifics on these software packages for C6800-SUP6T?
ceracaza08
Maybe you can find it under feature navigator... Just try
Reza Sharifi
The features set for both IP Services and Advanced Enterprise should be the same regardless of the platform or Sup.
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-15-0sy/product_bulletin_c25-687567.html
