Using IPsec encryption on switch links
andy_4578
Level 5
Level 5
Is it possible to set up switch links to use ipsec encryption? i.e....
3750-------------------2960  with the trunk using AES 256 encryption
I couldnt find any examples on the web or even any attempting it.
2 Accepted Solutions
With older switches, it is not possible, but if you are using the newer switches i.e. 3560X or 3750X you can use Macsec
Have a look at this link for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_1_se/configuration/guide/swmacsec.html
All the switches will be new as they havent been purchased yet
Ok, but make sure to talk to your sales and SE guys before purchasing, because not all feature sets i.e. Lan Base support it.
5 Replies 5
Abzal
Level 11
Level 11
Hi Andy,
Please refer this link, with the same problem
https://supportforums.cisco.com/thread/263171
Hope it will help.
Best regards,
Abzal
So is there any thing that could be done to secure LAN traffic on the switches? (This is for MOD so the LAN needs to be highly secure)
Yes that might be perfect. So that would prevent MAC spoofing of 3rd party contractors evesdropping on traffic?
