using rv345: Why Does My Router Lose Its Configuration after Reboot?
sanjeeth-pz
hi,
im using rv345. why does my config lost after a reboot of this machine.
i had user config, LAN config, VLAn, access rules and many more. on a reboot after a power maintenance, looks like rv345 has reset its config. i had to redo the config from scratch.
any workaround or action plan? thanks in advance.
5 Replies 5
Jitendra Kumar
Have you were saved your config to memory ??
Try below Solution..
Solution
The most likely reason why the router has bypassed the startup configuration stored in NVRAM is that the configuration register has not been set properly. To change your configuration register so that the router does not ignore or skip the startup configuration upon reboot or power cycle, complete these steps:
From the Router# prompt:
  1. Type configure terminal , and press ENTER.
  2. Type config-register 0x2102, and press ENTER.
  3. Type end, and press ENTER.
To verify the configuration register change, type show version at the Router# prompt, and review your show version command output again. Look for the configuration register setting, which must show a new value upon the next reload. Here is an example:
Router#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#config-register 0x2102
Router(config)#end
Router#show version
IOS (tm) 2500 Software (C2500-JS-L), Version 12.1(5),
 RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 25-Oct-00 05:18 by cmong
Image text-base: 0x03071DB0, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a),
Router uptime is 11 minutes
System returned to ROM by reload
System image file is "flash:c2500-js-l_121-5.bin"
cisco 2500 (68030) processor (revision D) with 16384K/2048K bytes of memory.
Processor board ID 03867477, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2142 (will be 0x2102 at next reload)
When the router is reloaded, the new configuration register setting becomes active.
Router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Your router now loads with the startup configuration, and the configuration register is set to 0x2102. Your configuration loads properly after the next reload or power cycle.
Jitendra
Jitendra
 @Jitendra Kumar
  1. Type config-register 0x2102, and press ENTER.   These commands are applicable to IOS based devices not RV-series.
 M.
yes .. Thanks for correct me..
Configuration Register Setting Router Behavior
0x102
  • Ignores break
  • 9600 console baud rate
0x1202
  • 1200 baud rate
0x2101
  • Boots into bootstrap
  • Ignores break
  • Boots into ROM if initial boot fails
0x2102
  • Ignores break
  • 9600 console baud rate default value for most platforms
0x2120
  • Boots into ROMmon
  • 19200 console speed
0x2122
  • Ignores break
  • 19200 console baud rate
0x2124
  • NetBoot
  • Ignores break
0x2142
  • Ignores break
  • Ignores the contents of Non-Volatile RAM (NVRAM) (ignores configuration)
0x2902
  • Ignores break
  • 4800 console baud rate
0x2922
  • Ignores break
  • 38400 console baud rate
0x3122
  • Ignores break
  • 57600 console baud rate
0x3902
  • Ignores break
  • 2400 console baud rate
0x3922
  • Ignores break
  • 115200 console baud rate
If the value you have for the configuration register is not in the table, then determine which bits are set in order to compute the value:
Bit Number Hex Meaning
00-030x0000-0x000FBoots Field Parameters:
  • 0x0000 - Stays at the system bootstrap prompt.
  • 0x0001 - Boots the first system image in onboard Flash memory (EPROM).
  • 0x0002-0x000F- Specifies a default netboot filename. Enables boot system commands that override the default netboot filename.
060x0040
  • Ignore NVRAM contents
070x0080
  • Disable boot messages
080x0100
  • Break disabled
090x0200
  • Causes the system to use the secondary bootstrap. This is typically not used (set to 0).
100x0400
  • IP broadcast with all zeros
5,11,120x0020, 0x0800, 0x1000
  • Console line speed
130x2000
  • Boots default ROM software if network boot fails
140x4000
  • IP broadcasts do not have net numbers
150x8000
  • Enables diagnostic messages
  • Ignores NVRAM contents
Jitendra
how do i enable terminal to the switch
which switch taking about ??
if you looking for an RV router terminal to enable ?? there is very limited on VR.
on a RV345 you go to Admin > Config management >  Source Filename & Destination Filename.  Change them via the drop down selection and to download select download to PC in the destination box.
The file is exported as an xml file which means you can edit the xml and upload with the changes you want.  You should be able to keep one as a template and modify this xml file for every new client including static dhcp clients.  It's pretty lengthy and appears to have every page of cofigs which obviously would make sense.
You can refer below discussion.
https://community.cisco.com/t5/small-business-routers/accessing-the-cli-on-a-rv340w-via-putty/td-p/3323015
thanks,
Jitendra
Jitendra
