02-24-2016 06:29 AM - edited 03-08-2019 04:42 AM
Hi Guys,
I am trying to establish the connection between 6880VSS pair and 6800IA using this SFP+fiber cable (SFP-10G-AOC10M) but the interface does not come up. I used a separate 10G SFP and separate fiber cable and it works fine. My 6880 version is 152-1.SY1a. Any restrictions using this cable? Or any added configuration needed? Any help that can be provided will be much appreciated. Thanks!
Solved! Go to Solution.
02-24-2016 08:15 AM
Hey
make sure you match the requirements of software/hardware for these cables , just search your cable type , 6880IA at the bottom
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
some you will see depending on IA need slightly different versions of ios
02-24-2016 08:15 AM
Hey
02-24-2016 11:01 AM
Thanks Mark, I upgraded the IA IOS and it works fine now!
