12-18-2012 08:59 AM - edited 03-07-2019 10:40 AM
We've got Cat6500s in our data centers, each with both ACE and FWSMs installed.
Our security folks want to have an IDS attached to each 6500 monitoring all traffic on selected networks; we (the network folks) want to have a sniffer available on each box for troubleshooting. The 6500 only allows for two simultaneous SPAN sessions, and the FWSM uses one of them, leaving only one left for the IDS and sniffer to share; but these are independent boxes and one SPAN isn't sufficient, hence we're trying to set up VACL capture instead, to direct "interesting" traffic to the IDS.
Conceptually this is pretty simple:
ip access-list extended ALL_TRAFFIC
permit ip any any
vlan access-map CAPTURE_TRAFFIC 10
match ip address ALL_TRAFFIC
action forward capture
vlan filter CAPTURE_TRAFFIC vlan-list 782
interface TenGigabitEthernet1/15
description IDS Box
switchport
switchport mode access
switchport capture
switchport capture allowed vlan 782
mtu 9216
load-interval 30
There's plenty of traffic on this network:
r-ASBDC-A#show interface Vlan782 | include rate
Queueing strategy: fifo
5 minute input rate 917000 bits/sec, 885 packets/sec
5 minute output rate 19492000 bits/sec, 2729 packets/sec
But the IDS box isn't receiving any traffic, and we're seeing lots of output drops:
r-ASBDC-A#show interface TenGigabitEthernet1/15
TenGigabitEthernet1/15 is down, line protocol is down (monitoring)
Hardware is C6k 10000Mb 802.3, address is 0021.a0ef.6d56 (bia 0021.a0ef.6d56)
Description: IDS Box
MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 10Gb/s
Transport mode LAN (10GBASE-R, 10.3125Gb/s), media type is 10Gbase-SR
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output 00:14:48, output hang never
Last clearing of "show interface" counters 00:15:17
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 5008317
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
This router is a 6509E/Sup720-PFC3CXL running 12.2(33)SXJ; the 10GE line card is a WS-F6700-DFC3C.
We've got this working successfully on outher 6500s where the outbound interface is GE, but haven't had any
luck doing this out 10GE ports. What are we missing?
12-18-2012 10:31 AM
Why don't you setup a monitor session to monitor the vlan or interface you want and send it to two separate interfaces, the 10Gi and Sniffer? On the Sniffer box, if you are using WireShark, you can setup capture filters to limit what you want to see.
monitor session <1-80> source vlan 782 both
monitor session <1-80> destination interface Te1/15, GiX/X "Sniffer interface"
Hope this helps!
12-18-2012 11:00 AM
As I said, we only have one SPAN available - since the FWSM sucks up one - and we need two independent monitor sessions. We use the one available SPAN for the sniffer - since with this we can sniff an interface, or a VLAN, or receive a remote SPAN from another switch in the data center. The IDS only needs to look at VLAN traffic, so VACL capture (if we can make it work) is appropriate for this.
12-19-2012 08:09 AM
Run these two commands to verify your config. It should list something similiar to below.
show vlan access-map CAPTURE_TRAFFIC
Vlan access-map "CAPTURE_TRAFFIC" 10 match: ip address ALL_TRAFFIC action: forward capture
show vlan filter
LAN Map CAPTURE_FILTER: Configured on VLANs: 782 Active on VLANs: 782
Your config looks correct and I dont know your setup but it may be an issue with the port. You may want to setup a laptop with WireShark or some other packet capture software, change the port to a Gi and see if its working correctly.
12-19-2012 01:24 PM
r-ASBDC-A#show vlan access-map CAPTURE_TRAFFIC
r-ASBDC-A#show vlan filter
VLAN Map CAPTURE_TRAFFIC:
r-ASBDC-A#sho run int Te1/15
Building configuration...
Current configuration : 177 bytes
description IDS Box
switchport
switchport capture
mtu 9216
load-interval 30
end
r-ASBDC-A#sho int TenGigabitEthernet1/15 | inc put_
Last input never, output 1d04h, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 92321601
I've tried adding "switchport capture allowed vlan all" to the interface config; this made no difference.
12-20-2012 07:26 AM
As I said your config and setup all looks correct so there is no problem in that area. You should now move on to testing if its the Te1/15 port that is causing the problem. Do you have any GigEthernet ports on your 6500? If so do as I suggested... change the switchport capture to the GigEthernet port and connect a packet capture machine. See if the packet capture is able to see any of the traffic.. you may want to try looking in the log, turn on terminal monitor if connecting through ssh or telnet, and try the debug vacl command to see any errors.
