VACL functioning
bapatsubodh
Level 7
Level 7
When we apply VACL to a VLAN by
vlan filter trial vlan-list 10 command,
and lets assume fa1/10 to fa1/15 are members of VLAN - 10. There is an accss-list defined in access-class. Does this access list logically gets applied to all member ports of this VLAN. That means traffic entering these ports and traffic exiting these ports will be inspectd by the access-class and corresponding access-list and action will be taken - Froward or drop. Or the traffic entering the switch originated by hosts is inspected and then dropped or forwarded? Is it direction based ?
What happends to traffic destined for other VLAN hosts generated by the hosts in the VLAN 10?
Please share the experience.
any link on cisco.com?
Thanks in advance
Subodh
Giuseppe Larosa
Hello Subodh,
you may read the vlan map section here
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swacl.html#wp1649190
VACL have no direction and they are the only way to apply a filter within a L2 broadcast domain.
You can give a direction by calling an ip ACL.
Hope to help
Giuseppe
