VACL on NX-OS (Nexus 7k) to block/filter traffic between hosts on the same VLAN (on same or different Nexus 7K switches)
raazans01
I am working on a solution to block traffic between hosts on the same subnet/VLAN to prevent lateral workstation communications. In my virtual lab (VIRL), I tested configurations using access-list and vlan access-map on IOS switch and it worked fine. When I tested the same exact configuration on a Nx-os (nexus 7K), it didn't appear to be working. When I tested connectivity between 2 hosts connected to the same N7k switch and on same VLAN 351, traffic was still passing and no hits were seen on the ACL.
Both hosts on n7k are connected to a switchport (no ip on the interface) and the switch is trunked to a router (Ios) and has a subinterface for VLAN 351 and has a dhcp pool for VLAN351 for the hosts on VLAN351.
On n7k, switch, created acls, vlan access-map  and used vlan filter vacl-name vlan-list 351 to apply the VACL.
Am I missing something in my configurations?
21 Replies 21
Below are router configs
Current configuration : 4477 bytes
version 15.7
hostname iosv-1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password cisco
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip dhcp excluded-address 172.24.51.1 172.24.51.2
ip dhcp pool infosec
 network 172.24.51.0 255.255.255.0
 default-router 172.24.51.1
no ip domain lookup
ip domain name virl.info
ip cef
ipv6 unicast-routing
ipv6 cef
username cisco privilege 15 secret 5 $1$ML2/$/EXoxHR/.pQ9qObMRCHs/0
redundancy
interface Loopback0
 description Loopback
 ip address 192.168.0.1 255.255.255.255
 ipv6 address 2001:DB8:B:0:1::2/128
 ipv6 ospf 1 area 0
 ipv6 ospf cost 1
interface GigabitEthernet0/0
 description OOB Management
 vrf forwarding Mgmt-intf
 ip address 10.255.0.2 255.255.0.0
 duplex full
 speed auto
 media-type rj45
interface GigabitEthernet0/1
 description to nx-osv-1
 no ip address
 ip ospf cost 1
 duplex auto
 speed auto
 media-type rj45
 ipv6 address 2001:DB8:A:0:1:1:0:6/126
 ipv6 ospf 1 area 0
 ipv6 ospf cost 1
interface GigabitEthernet0/1.1
 description infosec vlan
 encapsulation dot1Q 351
 ip address 172.24.51.1 255.255.255.0
router ospfv3 1
 router-id 192.168.0.1
 address-family ipv6 unicast
 exit-address-family
router ospf 1
 passive-interface Loopback0
 network 10.0.0.4 0.0.0.3 area 0
 network 192.168.0.1 0.0.0.0 area 0
router bgp 1
 bgp router-id 192.168.0.1
 bgp log-neighbor-changes
 neighbor 2001:DB8:B:0:1::3 remote-as 1
 neighbor 2001:DB8:B:0:1::3 description iBGP peer nx-osv-1
 neighbor 2001:DB8:B:0:1::3 update-source Loopback0
 neighbor 192.168.0.3 remote-as 1
 neighbor 192.168.0.3 description iBGP peer nx-osv-1
 neighbor 192.168.0.3 update-source Loopback0
 address-family ipv4
  network 192.168.0.1 mask 255.255.255.255
  no neighbor 2001:DB8:B:0:1::3 activate
  neighbor 192.168.0.3 activate
 exit-address-family
 address-family ipv6
  network 2001:DB8:B:0:1::2/128
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh server algorithm authentication password
ipv6 ioam timestamp
control-plane
banner exec ^C
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS  *
* education. IOSv is provided as-is and is not supported by Cisco's      *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any       *
* purposes is expressly prohibited except as otherwise authorized by     *
* Cisco in writing.                                                      *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
 password cisco
line aux 0
line vty 0 4
 exec-timeout 720 0
 password cisco
 login local
 transport input telnet ssh
no scheduler allocate
end
Hello
okay thanks for the clarification-
can you append the vacl to the rtr where the L3 interface for that vlan resides
Kind Regards
Paul
Hi Paul,
I can test that but my goal is to restrict traffic between 2 hosts in the
same VLAN and are connected to the same switch.
Hello
i understand as vacls work for traffic filtering within the same broadcast domain (vlan)
That vacl  should work on a specific switch for all hosts that are assigned to the specific vlan in the VACL
just interested to see the result if it’s appended on the L3 switch/router as well it shouldn’t make any difference tbh
By the way did you remove both sequence 20 and 99 from the vacl?
Kind Regards
Paul
No, I kept it as originally suggested this time around. But before posting
this question, I had also juat used a single ACL with permit IP any any and
used it in vlan access-map to drop packet. Basically deny all traffic. Even
that didn't work. I wonder if there is a Limitation in VIRL applying VACL
on NX-OS.
I just tested the most simple VACL on NX-OSv version 7.3, and it didn't work. I think it is a limitation of the VIRLimages  and/or GNS3. VACLs also don't seem to work in the  IOSvL2 15.2(4.0.55)E-1 image...
ip access-list acl-100
10 permit ip 172.24.51.2/32 172.24.51.3/32
vlan access-map vacl-seg 10
match ip address acl-100
action drop
vlan filter vacl-seg vlan-list 200
Hello
Given you brief test and @Georg Pauwen also, I guess you have your have your answer to why it iisnt working as it should
Kind Regards
Paul
