Very Basic VLAN Question
shahedvoicerite
I have what seems to be a very basic question, but even after doing many searches, and reading CCNP books,
I am not able to get a clear answer.
My Question :-
I have 3 switches   A <--> B <---> C, with links between A&B and B&C set as
                          switchport mode trunk
                          switchport allowed vlan all
           Switch B is in TRANSPARENT mode,
           Switch A  (Server) and C (client) use VTP.
Switch A and C have VLAN 5 configured
Now, If I want traffic over VLAN 5 to pass from a host on Switch A through to a host on Swiych C, do I need to :-
                      MANUALLY configure  VLAN 5 on switch B ??????
Or will trunk traffic pass right through Switch B ?
Also, if switch B is non-cisco &  NON-VLAN aware, but can accept jumbo frames, will vlan  5 make it across from A to C ?
2 Accepted Solutions
Jon Marshall
You need to have vlan 5 on the intermediate switch or traffic will not flow.
If switch B was non-vlan aware then only the native vlan would be allowed to pass so vlan 5 would have to be the native vlan on the trunk links.
Jon
Your'e not missing anything basic and it's a very good question.
I think the key issue here is it doesn't really make a lot of sense to have VTP server/client switches and then stick a VTP transparent switch in the middle. Either make all switches VTP transparent or use VTP Server/client on all switches. Mixing the 2 is as you say just creating more administration issues.
Personally i am a big fan of VTP transparent as it is inherently more secure and less easy to make a mistake with eg. overwriting the vlan database but in very large and dynamic environments there is a case for a VTP Server/client setup.
Jon
5 Replies 5
Jon Marshall
Jon
Thanks !!
That was my initial guess, but after reading more on Transparent mode, and how it "passes vtp advertisments",
I begin to wonder, what is the purpose of Transparent mode ??
I understand what it does, but whats the use of passing VTP information across, when it will break communication,
if the VLAN is not locally configured ??
I mean if you create a VLAN on A (Server) , and client C can see it, thats good.
       But if Switch C in the middle does not have it, then the VLAN will not be end-to-end.
       This will be a troubleshooting nightmare !!
Or am I missing something basic ??
Jon
Thanks again Jon !!
I think one of the reason for Transparent mode is introducing a new switch into the network, and not messing up the
vlan database (??)            http://www.cisco.com/warp/public/473/vtp_flash/
As an aside, I did my CCVP a couple of years ago, and I am pretty sure that at that time, VTP and trunking was explained in
much more detail, then it is now in the new SWITCH course ware !!
shahedvoicerite wrote:
Thanks again Jon !!
There are quite a few people on these forums who are not big fans of VTP
When you add a new switch it is actually worth changing the switch to transparent and then back to VTP client. This resets the revision number back to 0 but it doesn't mean you have to leave the switch as VTP transparent. The key point is that the revision number on the new switch must be lower than the current VTP server revision number or you can overwrite the VTP database.
Jon
