what does set spantree guard none mean
mahesh18
Level 6
Level 6
Hi all,
quick question  on cat os 6509 what does command
set spantree guard none  do??
Please explain this to me
thanks
mahesh
2 Accepted Solutions
Jon Marshall
Mahesh
It is to do with whether or not you enable STP rootguard and STP loopguard on a port. If you configure "set spantree guard none" on the port then you are effectively disabling both rootguard and loopguard on that port.
Jon
Giuseppe Larosa
Hello Mahesh,
it disables spanning-tree  guard on that port
none
Disables the spanning tree guard feature.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/setsn_su.html#wp1199243
Hope to help
Giuseppe
Jon Marshall
Mahesh
Jon
Many thanks for  quick reply
mahesh
Giuseppe Larosa
Hello Mahesh,
none
Hope to help
Giuseppe
mahesh
