Very Weird !!!
m.samouka
Hi All,
i have a new connection between the Main Office Site and a new remote site.
the 2 sites are connected by a fiber the main site by 6500 and the remote site with 3560.
you can find that all in the attachment.
the problem is that from my subnet i can connect (telnet & Ping) to the 6500 i also can connect to 2 other switch (2960) behind the remote site, but the problem is that i can't connect (telnet & ping) to the 3560!!! olthough i can reach the switches behind it.
can anyone help me please...
You have "ip routing" on the 3560's. This means that "ip default-gateway ..." is not in effect. You might want to use "ip route 0.0.0.0 0.0.0.0 ..." instead.
Please go to the cisco link explaining the difference between "ip route 0 0" and "ip default-gateway"
http://cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml
Hope this helps.
-Binh
8 Replies 8
JORGE RODRIGUEZ
Level 10
Level 10
Are you be able to console to these 3560?
1- Make sure the switches have ip default-gateway configured in them.
2- Are there any access-list / access-class aplied in vty lines ?
check this and get back.
Rgds
Jorge
Jorge Rodriguez
glen.grant
Sounds like no default gateway or default static route if the 3560 has ip routing turned on ..
i actually can connect to these 2 switches from the core switches. but i cant telnet or even ping them from my management subnet although i can telnet and reach the switches behind them!
for the default gateways on these switches you can find them in the configuration file.
does your 2960 switches behind 3560s have also their defualt-dateway as 172.17.0.2?
Jorge Rodriguez
no Actually the default gateway on these switches is the virtual ip of the 2 distribution switches (3560) of the remote site
Any News guys, this issue doesn't make sense and i can't solve it...
Hope this helps.
-Binh
Thanks Very much man :-)
you are right this was the problem, and it is solved now.
Many thanks for you all Guys.
(& Happy new year!!)
