Video conference device connected on switch is intermediately facing RTO?
vasanth77
Hi ,
We've Video conference device which is flapping when i connect to a port configured for both data and voice VLAN. But when I configure the port to only data access VLAN it is working properly without drop.
When port is configured in both data and voice VLAN the Video conference device is flappin between voice and data VLAN
can anybody tell me why this is happening or what is the issue. now it is working with data VLAN properly but I need to know why it is not working on both data and voice vlan configuration.
FYI
VC MAC address and IP address e4d7.2264.7736 -10.91.167.147
SWitch-7#show mac address-table interface fastEthernet 0/38
Mac Address Table
Vlan Mac Address Type Ports
181 e4c7.2264.7736 STATIC Fa0/38
Total Mac Addresses for this criterion: 1
SWitch-7#config
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line. End with CNTL/Z.
SWitch-7(config)#inter
SWitch-7(config)#interface fas
SWitch-7(config)#exit
Mac Address Table
167 e4c7.2264.7736 STATIC Fa0/38
With this configuration port is flapping between VLAN 167 & VLAN 181 as captured above
interface FastEthernet0/38
description --- User access port
switchport access vlan 167
switchport mode access
switchport voice vlan 181
switchport port-security maximum 5
switchport port-security aging time 1
switchport port-security violation restrict
switchport port-security aging type inactivity
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
ip dhcp snooping limit rate 100
the below configuration is working fine with video conference without any drop
when ping the IP of VC device
any quick response will help me
Thanks in advance
vasanth
Hello Vasanth,
what switch is this on ? I am just asking because on the (a lot) older switches you must configure a trunk.
Can you post the output of 'show version' ?
Hi Georg,
FYI
Switch-7#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.0(2)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 26-Jun-13 02:49 by prod_rel_team
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(46r)SE2, RELEASE SOFTWARE (fc1)
Switch-7 uptime is 14 weeks, 6 days, 19 hours, 13 minutes
System restarted at 17:07:27 UTC Fri Nov 25 2016
System image file is "flash:/c2960-lanbasek9-mz.150-2.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48PST-L (PowerPC405) processor (revision D0) with 65536K bytes of memory.
Processor board ID FOC1426W496
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : D0:57:4C:82:BB:00
Motherboard assembly number : 73-11882-08
Power supply part number : 341-0266-03
Motherboard serial number : FOC14261CRN
Power supply serial number : DCA1424H4UD
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C2960-48PST-L
System serial number : FOC1426W496
Top Assembly Part Number : 800-30874-04
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COMC400ARA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960-48PST-L 15.0(2)SE4 C2960-LANBASEK9-M
Configuration register is 0xF
What is the require configuration from switch side if it supports VC device on new device
IS that trunk or an data access VLAN is enough?
why it is not working on the data VLAN and Voice VLAN configured on same port?
Thanks for your quick response
Vasanth
what happens when you add 'switchport voice vlan dot1p' and/or 'switchport priority extend trust' to your interface configuration:
and/or
priority-queue out
mls qos trust cos
Hi Georg,
Thank you. Below the configuration I applied again with voice VLAN configuration and now the device is reachable without RTO. but I need to  check this with other ports with voice VLAN configured without configuring switchport priority extend trust configuration . I will confirm after
interface FastEthernet0/37
description --- VC device
priority-queue out
mls qos trust cos
end
