View Advanced mode of Cisco 9300L
Dao Quang Dung
I have used Cisco 9300L Switch but the interface displayed on the web is Basic mode. I want to show you the advanced mode on the web, how should I handle it?
ammahend
if you run the command "show privilege" it will show you what current privilege level you are logged in with.
C9300#show privilege
Current privilege level is 15
-hope this helps-
13 Replies 13
balaji.bandi
what advanced mode you looking for ? can you give example ?
what IOS XE code running ?
BB
I am using Cisco C9300L-24T-4X 16.12.4
The current viewport on my device is
I want to watch in advanced mode
i never seen this issue before - but can you please provide below information :
1. Check admin priveleges
2. check what License and image you have ( show version, show License).
BB
Core-SW-BBG#show version
Cisco IOS XE Software, Version 16.12.04
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.12.4, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 09-Jul-20 21:49 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.2r, RELEASE SOFTWARE (P)
Core-SW-BBG uptime is 22 weeks, 2 days, 18 hours, 48 minutes
Uptime for this control processor is 22 weeks, 2 days, 18 hours, 49 minutes
System returned to ROM by Reload Command
System image file is "flash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco C9300L-24T-4X (X86) processor with 1343576K/6147K bytes of memory.
Processor board ID FOC2509L7EZ
13 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : bc:e7:12:f2:6a:00
Motherboard Assembly Number : 73-19168-04
Motherboard Serial Number : FOC25084KEF
Model Revision Number : F0
Motherboard Revision Number : C0
Model Number : C9300L-24T-4X
System Serial Number : FOC2509L7EZ
Switch Ports Model SW Version SW Image Mode
* 1 29 C9300L-24T-4X 16.12.4 CAT9K_IOSXE INSTALL
Configuration register is 0x102
what me and sure @balaji.bandi  meaning you have not priv. level 15 and hence the gui appear like this.
it remove the config....etc. that appear only for priv.level 15.
check you access priv. level
Dao Quang Dung
I don't understand the implementations yet
Could you please guide me more specifically?
check the user has admin priv or post show run here.
BB
Config Switch Cisco 9300 Web GUI Basic - YouTube
check this video, see how add privilege to username to make it can access the gui full.
Dao Quang Dung
line con 0
 access-class TELNET in
 password 7 047A2F0B062F6
 login
 stopbits 1
line vty 0 4
 password 7 0227205602082F
 login
line vty 5 14
 login local
line vty 15
 login local
friend you access http not vty.
privilege is config with username
this from video I share.
can you please make second review of video.
ammahend
-hope this helps-
Dao Quang Dung
I have successfully configured
Core-SW-BBG#show privilege
Thank you so much
show privilege only indicate which privilege but you need username with 15 privilege.
I really confuse here.
anyway
Good luck.
