Viewing Nexus 7000 QoS Statistics
John5mith
I am working with a Cisco Nexus C7010C chassis with 4 VDCs, using the default QoS policy maps, running 6.1(2) and I am trying to view the QoS statistics for particular interfaces. I have run a few show commands which you can see below but I am not seeing the output I would expect to see which is matches against the DSCP markings. I have tried to run the commands against different interfaces which all provide the same output shown below. The only difference is when I run the 'sh system internal qos queuing stats int eth1/2' in the default VDC which provides a different output albeit showing zero figures.
Could anyone possibly shed some light on this?
sh policy-map int eth1/2 output type queuing
Global statistics status :   enabled
Ethernet1/2
  Service-policy (queuing) output:   default-4q-8e-out-policy
    Class-map (queuing):   1p3q1t-8e-out-pq1 (match-any)
      priority level 1
      queue dropped pkts : 0
    Class-map (queuing):   1p3q1t-8e-out-q2 (match-any)
      bandwidth remaining percent 33
    Class-map (queuing):   1p3q1t-8e-out-q3 (match-any)
    Class-map (queuing):   1p3q1t-8e-out-q-default (match-any)
Interface Ethernet1/2 statistics
Receive queues
This is not yet implemented
Transmit queues
John5mith
Anyone have any ideas?
David Varnum
Level 4
Level 4
Which model line card are you using?
Can you verify that 'qos statistics' is enabled in the default VDC?
N7K# sh run all | i 'qos statistics'
qos statistics
