Virtual Interfaces(VLAN) in 5512x
Jonn cos
Level 4
Level 4
Hi all,
in 5512x datasheet, what do they mean by Virtual Interfaces (VLANS) ? is it SVI or VLAN ?
http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/data_sheet_c78-701253.html
Bilal Nawaz
I believe it means SVI's or in this case, sub interfaces with a vlan tag on them. I know this bit for sure however my knowledge of ASA's is very limited, I think you can also create VLANs - in similar fashion.
Hth.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
slicerpro
Virtual interfaces are what you are calling SVI's. For example, you would have interface vlan1,  interface vlan2, etc. While you are still at it, name you interfaces using nameif command
interface vlan1
nameif outside
ip address x.x.x.x x.x.x.x
interface vlan 2
nameif inside
Optionally, you can configure security levels for the interfaces.  By default, the outside interface is assigned security level of 0 while the inside interface is assigned security level of 100.
