Virtual IP address in Backup interface
vijay kumar
Level 5
Level 5
Hi Experts ,
We are going to use interface level redundancy using "backup interface" feature in the router.
I am able to do all the configuration , except GLBP virtual ip address , I am getting the below error
% Address 192.168.1.1 in group 100 - interface FastEthernet0/0
Router Config:
Interface Fa 0/0
backup interface fa 0/1
ip address 192.168.1.2 255.255.255.0
glbp 10 ip 192.168.1.1
Interface fa 0/1
But not able to configure the GLBP VIP.
Any suggestion on this.
Vijay
Mark Malone
glbp does load balancing across its member interfaces , i doubt backup interface would be supported to work along side this as its supposed to be only used if necessary like an ISDN backup link if your primary link fails , using both together would contradict each other
