Virtual Switching
ashrafi73
  I have Cisco Cat 6509 with Supervisor Engine (WS-SUP720-3BXL) and IOS (12.2(33)SXH2a), I would like to know is it support Virtual Switching if yes is it stable.
Thanks.
3 Accepted Solutions
Jon Marshall
Thanks.
No you can't. You have the right IOS version ie. 12.2(33)SXH but your supervisors do not support it. You need either of the following supervisors -
VS-S720-10GE-3C
VS-S720-10GE-3CXL
see the VSS Q&A for full details -
http://www.cisco.com/en/US/customer/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b_ps2797_Products_Q_and_A_Item.html
Jon
Leo Laohoo
Another thing to consider is your 10Gb module.  VSS and 6704-10GE don't like each other especially when you want to link them both up to form a VSS Link (VSL).
ashrafi73 wrote:
Thanks Jon,
  One more question please, if I changed the supervisors to VS-S720-10GE-3CXL can I use it for cloude computing.
Ashraf
Cloud computing is a very large subject and VSS is only a very small part of that if used at all as Nexus switches are often deployed into this scenario. So simply having a VSS enabled pair of 6500 switches in no way means you are ready for cloud computing.  You may want to look at a couple of the design guides for cloud computing in the data centre and you'll see just how complex it can be and all the different technologies deployed -
http://www.cisco.com/en/US/customer/netsol/ns1050/networking_solutions_sub_program_home.html
Jon
5 Replies 5
Jon Marshall
Thanks.
VS-S720-10GE-3C
VS-S720-10GE-3CXL
Jon
Thanks Jon,
Ashraf
ashrafi73 wrote:
Thanks Jon,
Ashraf
Jon
Leo Laohoo
ashrafi73
Thanks Jon,
  I'll read more about the topics appreciate your support.
regards,
Ashraf
