Virus Flood Troubleshooting in LAN
ajay chauhan
Level 7
Level 7
Hi Guys,
I have some virus problem in my network can you pls guide me step by step how to find out which node is virus infected.
Anand Narayana
Level 6
Level 6
Hi Ajay,
infact i had a network virus which badly affected my network making the network 99% freeze. honestly telling, i identified with one the port which was blinking very fast & that made to suspect the pc which was connected on to that port, later when i removed that pc from the network, my network was back to normal.
so you have a physical check of the port blincking the switches. my network was affected with a network virus.
Well this can solve ur problem ...when u r able to see ur swith ..from remote how can we troubleshoot.
You can check with the broadcast keep increased drastically in the interfaces.
glen.grant
Turn on netflow on your layer 3 device and start looking for a one device going to many unknown addresses .
