VLAN ACL not working
radarbackwards
i want to block everything vlan 210 from accessing vlan 250 and vice versa but it doesnt work
ip access-list extended ALLOW_VLAN250
permit ip any any
ip access-list extended BLOCK_VLAN210
deny ip any any
deny icmp any any
vlan access-map VLAN250MAP 250
action forward
match ip address ALLOW_VLAN250
vlan access-map VLAN250MAP 210
action drop
match ip address BLOCK_VLAN210
vlan filter VLAN250MAP vlan-list 210
Try this:
VLAN 210: 1.1.1.0/24
VLAN 250 2.2.2.0/24
ip access-list extended VLAN-FILTER
permit ip 1.1.1.0 0.0.0.255 2.2.2.0 0.0.0.255
ip access-list extended ANY-TRAFFIC
permit ip any any
vlan access-map VLAN-FILTER-210 10
match ip address VLAN-FILTER
action drop log
vlan access-map VLAN-FILTER-210 20
match ip address ANY-TRAFFIC
action forward
vlan filter VLAN-FILTER-210 vlan-list  210
5 Replies 5
ALIAOF_
Level 6
Level 6
I have done something like this but just using ACL's and then applying to the VLAN interface "in"
Can you paste the ip access list in here too?
this is the only ACL
permit ip any any
deny ip any any
deny icmp any any
fb_webuser
Level 6
Level 6
Hi, you might want to add VLAN250 in your filter list. VACL does work on only one direction as we have tried this on some of our call recording packet captures. Also, why do you have to go all the way down to VACL level if you can have it blocked on the L3 port/VLAN side? Just a thought.
Posted by WebUser John Patrick Lopez from Cisco Support Community App
hi John,
I already added 250 on my filter list - but it still aint working, i want to go down to the VACL level because it is a requirement for compliance we are working right now
permit ip any any
deny ip any any
deny icmp any any
action forward
action drop
vlan filter VLAN210MAP vlan-list 250
Try this:
VLAN 250 2.2.2.0/24
permit ip any any
action drop log
action forward
