VLAN bridge with Catalyst 3750
rodolfobm
Hi, all!
I have 3 VLANs here that need to be on the same network segment.  They are going to be used by our Wi-Fi network (with Aironet APs), bound to 3 different SSIDs (as Aironet APs doesnt allow multiple SSID per VLAN), each one with a different authentication method and server.
Is there a way to bridge those VLANs together with a Catalyst 3750 switch?  I tryed configuring an IP address on one of the VLAN interfaces, then configuring a bridge with the vlan-bridge protocol (Catalyst 3750 doesnt have the "ieee" bridge protocol type) and put all 3 VLAN interfaces on the same bridge-group, but it didnt work (even with "bridge x route ip").
I also tryed configuring IRB bridging, with the 3 VLAN interfaces on the same bridge-group and an IP address on the BVI interface (the way I used to do with old 2600 routers).  Same result.
(actually, I didint test to see if the interfaces are actually being "bridged", but I see neither of them can reach the router)
Is there a way to do this?
Thanks in advice!
Rodolfo
Abzal
Level 7
Level 7
You can create SVI interfaces for VLANs on 3750, create VLANs on AP connect them as trunk I have done it myself
VLAN 22 e.g. Wireless LAN, also you can create few wireless LAN.
3750:
int vlan 10
ip add 10.0.10.1 255.255.255.0
ip helper-address 10.0.10.10
no shut
int vlan 22
ip add 10.0.22.1 255.255.255.0
no shut
int g1/0/1
switchport mode trunk
switchport trunk native vlan 10
AP:
dot11 vlan-name Native_vlan vlan 10
dot11 vlan-name eni.wip vlan 22
dot11 ssid test
   vlan 22
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 040A59555B701E1D5D
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 22 mode ciphers tkip
ssid test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.22
encapsulation dot1Q 22
no ip route-cache
bridge-group 22
bridge-group 22 subscriber-loop-control
bridge-group 22 block-unknown-source
no bridge-group 22 source-learning
no bridge-group 22 unicast-flooding
bridge-group 22 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.22
ip dhcp relay information trusted
no ip route-cache
bridge-group 22
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.10
no ip route-cache
bridge-group 1
interface FastEthernet0.22
no ip route-cache
bridge-group 22
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip default-gateway 10.0.10.1
Please rate helpful posts.
Best regards,
Abzal
