VLAN changing
geocoles
Frequent Visitor
Frequent Visitor
I have a strange one. C9200 switch, 17.03.04b. Setting up a port for a postage machine. config as follows:
ip dhcp pool cin-6
address 10.3.6.2 client-id 0100.1b00.4116.4d
interface GigabitEthernet1/0/15
description Postage machine
switchport access vlan 6
switchport mode access
speed 100
duplex full
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
If I view the port(sh run) before the device is brought online I see it in VLAN 6, as expected.
But once the device comes online, the VLAN changes to VLAN 20. The config of the device is very simple, either DHCP or static. It is set for DHCP.
Don't understand why it changes VLANs, any ideas?
Richard Burts
Are there any log messages generated when the device is brought on line? If so please post them.
Would you post the output of show interface status after configuration and before bringing the device on line, bring the device on line and post the output of show interface status when machine is on line.
Rick
Hello
Seems strange -
Have you tried defaulting the port and reconfiguring also not enable bpdufilter
conf t
default interface GigabitEthernet1/0/15
switchport host
speed 100
duplex full
Kind Regards
Paul
change of VLAN from
1- 802.1x which you dont use
2- macro or EEM <<- this can also change VLAN
if not point 2
are vlan 20 is native vlan ?
MHM
