12-05-2006 09:59 PM - edited 03-05-2019 01:11 PM
HI,
I am trying to configure VLANs in 2950 switch and connect the trunk ports 16,17 to the router .
Now the problem is When I enable any One VLAN interface the other one goes down automatically .
for example :
#vlan 1
#no shut
It automatically gives VLAN 2 is administratively down .
If i again enable VLAN 2 it says ..
VLAN 1 administratively down...
I also tried enabling spanning-tree portfast but no use ??
where is the problem?Pls see the config
Thanks ..
sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA8a, RELEASE SOFTWARE (fc1)
ROM: Bootstrap progis C2950 boot loader
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA8a.bin"
cisco-2950#sh run
Building configuration...
version 12.1
!interface FastEthernet0/1
switchport access vlan 2
switchport mode access
interface FastEthernet0/2
switchport access vlan 4
interface FastEthernet0/3
switchport access vlan 6
interface FastEthernet0/4
switchport access vlan 8
interface FastEthernet0/5
switchport access vlan 10
interface FastEthernet0/6
switchport access vlan 12
interface FastEthernet0/7
switchport access vlan 14
interface FastEthernet0/8
switchport access vlan 16
interface FastEthernet0/9
switchport access vlan 18
interface FastEthernet0/12
switchport access vlan 24
interface FastEthernet0/16
switchport trunk allowed vlan 2,4,6,8,10,12,14
switchport mode trunk
interface FastEthernet0/17
switchport trunk allowed vlan 16,18,20,22,24,100
interface FastEthernet0/20
switchport access vlan 100
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip address 10.1.0.254 255.255.255.0
no ip route-cache
shutdown
interface Vlan2
ip address 10.2.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan3
no ip address
no ip route-cache
interface Vlan4
ip address 10.4.0.6 255.255.255.248
no ip route-cach
interface Vlan6
ip address 10.6.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan8
ip address 10.8.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan10
ip address 10.10.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan12
ip address 10.12.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan14
ip address 10.14.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan16
ip address 10.16.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan18
ip address 10.18.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan20
ip address 10.20.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan22
ip address 10.22.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan24
ip address 10.24.0.6 255.255.255.248
no ip route-cache
shutdown
interface Vlan100
no ip address
no ip route-cache
shutdow
cisco-2950#
12-05-2006 10:31 PM
Hi Friend,
2950 is a pure payer 2 switch and only one layer 3 logical interface can be up at a time for admin/management purpose.
You can only create vlans at layer 2 on 2950 switches and all will be in active state if there is a trunk carrying those vlans.
Just create the vlans on 2950 and check the status in "sh vlan"
You can create the subinterfaces on your router for the number of vlans which you want to have intervlan routing and can define encapsulation dot1q command with vlan number under those subinterfaces.
Have a look at this link for more information
http://www.cisco.com/warp/public/473/50.shtml#801.1Q
Ankur
*Pls rate all helpfull post
12-05-2006 10:33 PM
Hi Murthy
You can have L2 Vlans enabled on your Cisco 2950 switch which is basically a Layer 2 switch provided you haven't exceeded the maximum permissible limit.
From the config which you have posted its very much clear that you are trying to create SVI (VLAN interfaces assigned with IP address).In Layer 2 switches such as Cisco 2950 you can have only one SVI up and running and when you try to enable the other SVI the existing will go down(admin down).This is the default nature and a limitation of a Layer 2 Switch.
You can have different Layer 2 vlans created under VLAN database and assign them under the respective interface using switchport access vlan and allow them on a trunk which is connected to the router.
On the router if you have IP Plus ios feature or a new ios code which can allow you to create and assign sub interfaces with encapsulation as 802.1q you can terminate the SVI.
regds
12-06-2006 05:38 AM
Hi Prem & Ankur,
Thanks for the reply !!
did u mean to say that i should not specify the IP Address in the Switch End in the VLan interface !!
Pls correct me if iam wrong ?
Thanks & Regards
12-06-2006 06:28 AM
Hi Friend,
Yes you should only specify one vlan interface with an ip address just for management purpose.
On 2950 switch which is a layer 2 switch you should only create only one vlan interface with an ip address for management purpose and if you try to create second vlan interface and assign an ip address it will accept it but if you say "no shut" it will become active and previous configured interface will go down.
So only one vlan interface with an ip address is allowed to be active at a time for management purpose.
If its a layer 3 switch like 3550,3560 and above you can create multiple vlan interface with an ip address and all can be active at a time and can have routing between them.
Ankur
*Pls rate all helpfull posr
12-07-2006 02:05 AM
Hi ,I have modified my present config and created one VLAN interface with 10.1.0.253 .
Now the problem is i am not able to ping any of other Vlans ....
OSPF is configured at the router end .
pls see switch&router configs .
ROUTER-2600 CONFIG:
interface FastEthernet0/0
description *** Connected to VLAN2,4,6,8,10,12,14****
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 4
ip address 10.4.0.5 255.255.255.248
interface FastEthernet0/0.2
encapsulation dot1Q 6
ip address 10.6.0.5 255.255.255.248
interface FastEthernet0/0.3
encapsulation dot1Q 8
ip address 10.8.0.5 255.255.255.248
interface FastEthernet0/0.4
encapsulation dot1Q 10
ip address 10.10.0.5 255.255.255.248
interface FastEthernet0/0.5
encapsulation dot1Q 12
interface FastEthernet0/0.6
encapsulation dot1Q 14
ip address 10.14.0.5 255.255.255.248
interface FastEthernet0/0.7
encapsulation dot1Q 2
ip address 10.2.0.5 255.255.255.248
ip address 10.1.0.253 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 18
ip address 10.18.0.5 255.255.255.248
interface FastEthernet0/1.2
encapsulation dot1Q 16
ip address 10.16.0.5 255.255.255.248
interface FastEthernet0/1.3
encapsulation dot1Q 20
ip address 10.20.0.5 255.255.255.248
interface FastEthernet0/1.4
encapsulation dot1Q 22
ip address 10.22.0.5 255.255.255.248
interface FastEthernet0/1.5
encapsulation dot1Q 24
ip address 10.24.0.5 255.255.255.248
router ospf 1
log-adjacency-changes
network 10.1.0.0 0.0.255.255 area 1
network 10.2.0.0 0.0.255.255 area 2
network 10.4.0.0 0.0.255.255 area 2
network 10.6.0.0 0.0.255.255 area 2
network 10.8.0.0 0.0.255.255 area 2
network 10.10.0.0 0.0.255.255 area 2
network 10.12.0.0 0.0.255.255 area 2
network 10.14.0.0 0.0.255.255 area 2
network 10.16.0.0 0.0.255.255 area 1
network 10.18.0.0 0.0.255.255 area 1
network 10.20.0.0 0.0.255.255 area 1
network 10.22.0.0 0.0.255.255 area 1
network 10.24.0.0 0.0.255.255 area 1
SWITCH CONFIG :
VLAN:
interface Vlan1
no ip route-cache
TRUNK Port 16 & 17 :
switchport trunk allowed vlan 1,16,18,20,22,24
