Vlan Configuration between Cisco and Sonicwall
vinish milton
I am new the Vlan configuration. Recently I have purchase cisco L3. I want my sonicwall  to be the primary L3 routing. We have around 2000 users. Users need to be get ip from sonicwall(DHCP).
My ip plan is as below.
Sonicwall Ip : 10.10.20.1
Cisco 3560 Management Vlan1 ip : 10.10.20.2
Vlan 10 : 10.10.0.1/255.255.252.0
Vlan 20  : 10.20.0.1/255.255.254.0
Vlan 30  : 10.30.0.1/255.255.254.0
vlan 40 : 10.40.0.1/255.255.252.0
Vlan 50  : 10.50.0.1/255.255.255.254.0
Vlan 60 10.60.0.1/255.255.255.0
Vlan 70 ip : 10.70.0.1/255.255.254.0
Vlan 80 : 10.80.0.1/255.255.254.0
All Vlan port will connected to respective building L2 switch(  like Vlan 10 Port 1 connected to Academic building cisco L2 switch, Vlan 20 port 2 connected to mechanical building L2 et.,) I have 8 access points. It connected to L2 switches. Access point controller connected to L3 switch. User will be get ip from sonicwall.
How can I configure L3 and L2 switch? Pl guide.
Thanks.
25 Replies 25
hi,
i had done all configuration, now all Vlan is working fine and VLan users able to get internet. Now my problem is sonicwall did't get any VLAN ARP entry except 10.10.20.x. I had talk to sonicwall expert, he say need to be check & configure at Cisco L3 then only ARP entry wiill catch Sonicwall. Can you please tell me how can i configure at L3.
Thanks.
Hi Vinish,
     Can you please show me the VLAN ARP configuration description so that i can resolve your issue.
Thanks and regards,
Chandhuru.M
Thanks and regards, Chandhuru.M
Hi Chandhur,
pl see the L3 configuration.
User Access Verification
Switch#sh run
Building configuration...
Current configuration : 6453 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 $1$rv8J$rIMAenBP8yMbdlr2HbFPM.
no aaa new-model
system mtu routing 1500
ip routing
crypto pki trustpoint TP-self-signed-1787939840
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1787939840
revocation-check none
rsakeypair TP-self-signed-1787939840
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
shutdown
interface GigabitEthernet0/1
shutdown
interface GigabitEthernet0/2
shutdown
interface GigabitEthernet0/3
shutdown
interface GigabitEthernet0/4
shutdown
interface GigabitEthernet0/5
shutdown
interface GigabitEthernet0/6
shutdown
interface GigabitEthernet0/7
shutdown
interface GigabitEthernet0/8
shutdown
interface GigabitEthernet0/9
shutdown
interface GigabitEthernet0/10
interface GigabitEthernet0/11
description connected to Academic Building L2
switchport access vlan 10
switchport mode access
interface GigabitEthernet0/12
description connected to Mechanical building L2
switchport trunk allowed vlan 1,10,20,30,40,50,60,70,80,90
switchport mode trunk
interface GigabitEthernet0/13
description connected to admin L2
interface GigabitEthernet0/14
description connected to Diploma
interface GigabitEthernet0/15
description connected to MBA
interface GigabitEthernet0/16
description connected to Workshop L2
switchport access vlan 60
interface GigabitEthernet0/17
description connected to E&TC
switchport access vlan 70
interface GigabitEthernet0/18
description connected to Computer
switchport access vlan 80
interface GigabitEthernet0/19
description connected to AP controloer
interface GigabitEthernet0/20
description connected to Test switch
switchport access vlan 90
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
description connected to E5500
interface GigabitEthernet0/24
Shutdown
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address 10.10.20.2 255.255.255.0
no ip mroute-cache
interface Vlan10
ip address 10.10.0.1 255.255.252.0
ip helper-address 10.10.20.1
interface Vlan20
ip address 10.20.0.1 255.255.254.0
interface Vlan30
ip address 10.30.0.1 255.255.254.0
interface Vlan40
ip address 10.40.0.1 255.255.252.0
interface Vlan50
ip address 10.50.0.1 255.255.254.0
interface Vlan60
ip address 10.60.0.1 255.255.255.0
interface Vlan70
ip address 10.70.0.1 255.255.254.0
interface Vlan80
ip address 10.80.0.1 255.255.254.0
interface Vlan90
ip address 10.90.0.1 255.255.255.0
ip default-gateway 10.10.20.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.20.1
ip http server
ip http secure-server
snmp-server community public RO R0
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
end
Switch#
Dear Vinish,
     You made right configuration over in L3 switch. Once again check out the L2 switch configuration. I thought the problem over in Sonic wall.
Thanks and regards,
Chandhuru.M
Dear Chandhuru,
Thanks for your reply, i have attched my sonicwall ARP configuraion. pl see
Dear Vinish,
     Can you able to get VLAN ARP description in L3 switch. Using 'sh arp' command to get it and make sure the L3 switch could able to get ARP description. Let me know.
Thanks and regards,
Chandhuru.M
Dear Chandhuru,
        i am able to get VLAN ARP in L3. but my issue is i need to get same as my sonicwall, so that i can do Mac finding.
Switch#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.80.1.91             22   6c62.6da3.1766  ARPA   Vlan80
Internet  10.50.0.56             59   4437.e661.c0c0  ARPA   Vlan50
Internet  10.70.1.77              6   0011.11c6.ca00  ARPA   Vlan70
Internet  10.20.0.30              0   6c62.6d8c.588f  ARPA   Vlan20
Internet  10.80.0.91              8   4437.e661.2315  ARPA   Vlan80
Internet  10.50.0.57              4   4437.e661.d520  ARPA   Vlan50
Internet  10.30.1.20            107   0025.111b.da42  ARPA   Vlan30
Internet  10.70.0.77              5   d43d.7ead.38ce  ARPA   Vlan70
Internet  10.20.1.30              8   6c62.6d8f.217e  ARPA   Vlan20
Internet  10.10.0.1               -   6c41.6a91.cc41  ARPA   Vlan10
Internet  10.20.0.28            120   d43d.7e12.cbd2  ARPA   Vlan20
Internet  10.30.1.23            134   d43d.7e12.cb17  ARPA   Vlan30
Internet  10.80.0.88            123   6c62.6da3.1765  ARPA   Vlan80
Internet  10.20.1.28             31   8c89.a5f6.72bf  ARPA   Vlan20
Internet  10.30.0.23              0   001f.d033.06da  ARPA   Vlan30
Internet  10.80.1.88             12   8c89.a5f6.7230  ARPA   Vlan80
Internet  10.80.1.95              3   001f.d034.3163  ARPA   Vlan80
Internet  10.80.0.95              0   d43d.7ead.3ed1  ARPA   Vlan80
Internet  10.10.0.5               5   6c62.6d8c.538b  ARPA   Vlan10
Internet  10.80.1.93            111   4061.8663.6373  ARPA   Vlan80
Internet  10.10.0.6               0   e839.35b0.684a  ARPA   Vlan10
Internet  10.80.0.93              3   4061.8663.6368  ARPA   Vlan80
Internet  10.10.0.7               0   0021.5a5d.2c94  ARPA   Vlan10
Internet  10.30.0.28             61   001f.d034.36de  ARPA   Vlan30
Internet  10.20.1.23            100   d43d.7e12.cad5  ARPA   Vlan20
Internet  10.40.2.40              3   4437.e667.f84c  ARPA   Vlan40
Internet  10.80.0.82              3   4437.e668.1cd1  ARPA   Vlan80
Internet  10.10.0.8               0   6c62.6da6.9735  ARPA   Vlan10
Internet  10.10.1.8              16   001f.d031.9f05  ARPA   Vlan10
Internet  10.30.1.28             27   001f.d030.622f  ARPA   Vlan30
Internet  10.20.0.23              6   d43d.7e12.cb22  ARPA   Vlan20
Internet  10.80.1.82              0   d43d.7e12.cbdb  ARPA   Vlan80
Internet  10.10.0.9              32   0017.6110.933c  ARPA   Vlan10
Internet  10.10.2.8              72   8c89.a5f6.7033  ARPA   Vlan10
Internet  10.50.0.50              0   4437.e661.c110  ARPA   Vlan50
Internet  10.70.1.71              3   6c62.6da3.171e  ARPA   Vlan70
Internet  10.20.1.20             29   8c89.a5f6.726e  ARPA   Vlan20
Dear Vinish,
     So that, from your post i came to know that L3 switch can able get ARP description and also L3 communicate with sonicwall. It means internet can be passing through the sonicwall and L3 to all VLANs so problem is not in L3 configuration.
     My thought was sonicwall can able to get management VLANs ARP description only. It cant able to get the other VLANs ARP description. Just verify with your soniwall expert.
Thanks and regards,
Chandhuru.M
Dear Chandhuru,
        Thanks for your reply, i will talk to them & let you know.
      i want stop intervlan comunication between Vlan70 and all Vlans. how will i do that. pl guid
JDO
Hi All...
I have cisco 3650 switch. I have configured the vlan 10 and vlan 20 at the moment.
I also assigned port gi1/0/24 10.8.2.2 and connect to my Primary Sonicwall 10.8.2.1
And from my Primary Sonicwall connected to my ISP.
All the above have successfully connected to internet and able to communicate within the vlan.
I have another Secondary Sonicwall and already set as HA to my Primary Sonicwall. (Done & successfull)
But now i need to connect to my Secondary Sonicwall to my switch 3650 (the same switch as above) to port gi1/0/23.
How can i configure on that.
