VLAN Connectivity Issue
farhadsultani
Visitor
I have a VTP domain of 8 switches(cisco 3560) with 400 VLANs, on one of the switch I am getting the following log message:
%SPANTREE_VLAN_SW-2-MAX_INSTANCE: Platform limit of 128 STP instances exc
I have assigned IP address to VLAN 11 and 12 on all of the switches it works properly unless on the switch which gives the above message.
VLAN 1 is also assigned IP address on all of the switches but it works well even on the switch which gives the above message.
Please suggest me a solution to fix this issue.
Thanks in advance for your replies.
Dennis Mink
Depending on what switches you are using, have a look at this older post:
https://supportforums.cisco.com/discussion/11423151/catalyst-3750-having-more-128-vlans
Please rate if helpful
Please remember to rate useful posts, by clicking on the stars below.
