vlan database mode vs conf T mode
davisr651
studying for ccna, looking at creating vlans. Im confused, is there two ways to create a VLAN? in vlan database mode, or config t mode? if so, why? if it is this way, i assume on the ccna, either way i use would be correct?
balajitvk
Level 4
Level 4
Hi Davis,
Ya, as u said there are two ways to create vlans. But the database mode of creation will be deprecated in the new versions and better to use Config mode.
Rate if it does,
Rgs,
balajitvk
Level 4
Level 4
Hi Davis,
Rate if it does,
Rgs,
