VLAN enabled switch
phong.vuong
can you recommend a VLAN enabled layer 3 cisco switch for small office of 20 servers + laptops/desktops + printers all together?
Giuseppe Larosa
Hello Phong,
you can go with the C3560 series with ip services images.
There are models with 24 ports and other with 48 ports.
see the datasheet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
other choice can be a C3750 series
Hope to help
Giuseppe
Giuseppe Larosa
Hello Phong,
see the datasheet
Hope to help
Giuseppe
hi Phong,
Cisco 3560 or Cisco 3750 can be done. It depends on what you really want. If your network is alive. It may be hard to re-configure ip addresses of all servers. It should be the same. You then seperate vlan_server and vlan_user. Are you mapping all printers with thier name? If you're using ip addresses of printers then you're going to re-map them again(if vlan configured).
Toshi
