Vlan Filter between Nexus 2000 / 3750-X
Dear all,
I have 2 Cisco Nexus 5000 with each 2 Nexus 2000 in FEX Mode. My Vlan are all in fabric mode.
I would tried to connect a catalyst 3750-X and a nexus 2K together in trunk with filter vlan.
NEXUS 2000 <== Port-Channel ===> Cisco 3750X
N2K :
Po: switchport mode trunk
      switchport trunk allowed vlan 10,20,30
Interface  : e101/1/1 & e102/1/1
                channel-group 1 mode active
3750X
Po : switchport mode trunk
      spanning-tree bpdufilter enable
interfaces : Gi0/1 & Gi0/2
It doesn't work in allowed vlan (not connection, nothing all) but without the command allowed vlan, my po and my interfaces are up. I tried wihtout LACP in mode etherchannel only but it was the same result.
Questions :
- Could you tell me if this a mechanism with the fabric mode or if there is something to add or modify ?
-  If I have a VLAN 40 from my 3750X but not in the 2K, it is forwarding accross my interface ?
Thanks for your help.
Have a nice day,
Matthieu
Reza Sharifi
The 2ks are desihned for connecting end devices e.g servers, workstations, etc.. to the network and not connecting other switches to it.  You can however connect your 3750X to both 5ks using vPC.
from the config guide:
Any device running spanning tree connected to a Fabric Extender host interface results in that host
interface being placed in an error-disabled state when a BPDU is received.
link
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_6_0/b_Configuring_the_Cisco_Nexus_2000_Series_Fabric_Extender_rel_6_0.pdf
