VLAN Flapping Between Ports - HSRP Configuration
aaronmcneil15
We have a system with 2 redundant Stratix 5410 switches are configured with hsrp. We have recently encountered what seems to be a widespread problem where if one of the switches get reset, we get constant port flapping errors that make our network unstable. If we shut one of the ports connecting the 2 5410s, the flapping issue goes away, only to reoccur as soon as the port is reenabled. Below is the VLAN, Spanning Tree and port configurations for the 2 switches. Any suggestions would be great.
Switch 1:
interface Vlan1
description Not Used
no ip address
shutdown
interface Vlan20
description Firewall LAN Transit
ip address 10.53.120.42 255.255.255.248
standby 19 ip 10.53.120.41
standby 19 timers 1 4
standby 19 priority 110
standby 19 preempt
interface Vlan30
description SCADA Management Gateway
ip address 10.53.123.2 255.255.255.0
standby delay minimum 30 reload 60
standby 30 ip 10.53.123.1
standby 30 timers 1 4
standby 30 priority 110
standby 30 preempt
interface Vlan101
description ESDNet Gateway
ip address 192.168.3.2 255.255.255.0
standby 101 ip 192.168.3.1
standby 101 timers 1 4
standby 101 priority 110
standby 101 preempt
interface Vlan102
description RIONet Gateway
ip address 192.168.4.2 255.255.255.0
standby 102 ip 192.168.4.1
standby 102 timers 1 4
standby 102 priority 110
standby 102 preempt
interface Vlan105
description SCP MCC Gateway
ip address 192.168.5.2 255.255.255.0
standby 105 ip 192.168.5.1
standby 105 timers 1 4
standby 105 priority 110
standby 105 preempt
interface Vlan106
description UCP MCC Gateway
ip address 192.168.6.2 255.255.255.0
standby 106 ip 192.168.6.1
standby 106 timers 1 4
standby 106 priority 110
standby 106 preempt
interface Vlan172
description ControlNet Gateway
ip address 10.53.122.2 255.255.255.0
standby 172 ip 10.53.122.1
standby 172 timers 1 4
standby 172 priority 110
standby 172 preempt
interface Vlan173
no ip address
shutdown
interface Vlan999
no ip address
shutdown
interface Port-channel1
switchport trunk allowed vlan 20,30,101,102,105,106,172,173
switchport trunk native vlan 30
switchport mode trunk
end
interface TenGigabitEthernet1/27
description HSRP Link 1
channel-group 1 mode active
end
interface TenGigabitEthernet1/28
description HSRP Link 2
end
spanning-tree mode mst
spanning-tree loopguard default
spanning-tree portfast edge bpduguard default
spanning-tree portfast edge bpdufilter default
spanning-tree mst hello-time 1
spanning-tree mst forward-time 4
spanning-tree mst max-age 12
spanning-tree mst 0-3 priority 4096
spanning-tree vlan 20,30,101-102,105-106,172-173 priority 4096
spanning-tree vlan 20,30,101-102,105-106,172-173 hello-time 1
spanning-tree vlan 20,30,101-102,105-106,172-173 forward-time 4
spanning-tree vlan 20,30,101-102,105-106,172-173 max-age 12
Switch # 2:
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 10.53.120.43 255.255.255.248
standby 19 priority 90
standby 19 preempt
interface Vlan30
ip address 10.53.123.3 255.255.255.0
standby 30 priority 90
standby 30 preempt
interface Vlan101
ip address 192.168.3.3 255.255.255.0
standby 101 priority 90
standby 101 preempt
interface Vlan102
ip address 192.168.4.3 255.255.255.0
standby 102 priority 90
standby 102 preempt
interface Vlan105
ip address 192.168.5.3 255.255.255.0
standby 105 priority 90
standby 105 preempt
interface Vlan106
ip address 192.168.6.3 255.255.255.0
standby 106 priority 90
standby 106 preempt
interface Vlan172
ip address 10.53.122.3 255.255.255.0
standby 172 priority 90
standby 172 preempt
interface Vlan173
no ip address
shutdown
interface Vlan999
no ip address
shutdown
end
end
end
spanning-tree mst 0-3 priority 8192
spanning-tree vlan 20,30,101-102,105-106,172-173 priority 8192
9 Replies 9
marce1000
 - Configure a central syslog server on the stratix and the cisco switches ; examine logs arriving on it when these issues start ;
        You may get more insights ,
 M.
Attached is a screenshot of the switch logs as the issue is happening.
aaronmcneil15
Question to anyone who might know, should I have the Standby Preempt statement in both switches, or only the one I wish to be primary?
Assuming that you care about which switch is primary when both switches are active then preempt is important on the primary switch. That means that if there was some problem, the primary failed for some reason, the other switch became the active HSRP peer, the original primary switch comes back into service, the primary switch can become the active peer. Without preempt the "primary" switch would not become the active peer.
Since there is not anything in your config that would lower the priority of the primary then there is no benefit in configuring preempt on the secondary switch.
Rick
If preempt is present on both switches, could that cause problems if the primary switch would lose power temporarily? We see the port flapping issue when the primary switch is rebooted.
If preempt were present on both switches it would not cause any problem. To re-phrase my previous response - having preempt on the secondary switch will do not harm, but it also will not provide any benefit. So my suggestion is to keep things simple where we can and not put preempt on the secondary switch.
Rick
Preempt with delay
Or
EEM shutdown the port
Can solve issue.
Hello
spanning-tree portfast edge bpdufilter default < wow!!!!  I would remove this ASAP , it can cause you all sorts of problems, including the one you are experiencing now.
Also your running mst spanning-tree, but you are have vlan priority's not relating to mst mode and are manually pruning the switch trunks however MST is per-instance NOT per-vlan so you shouldn't be pruning the trunks
Kind Regards
Paul
BrianSekleckiGE
I was going to ask you if you were also running (but not shown /exempted from your config) if you were also running PRP (using these IE4000/Stratix 5400's as a PRP Redbox).
Because STP doesn't run on PRP interfaces, one has to ensure that VLANs being sent to a PRP do not transit over the ISL/Dot1Q Trunk between the Switches/Redboxes.  This would be accomplished with a very selective "switchport trunk allowed vlans [X]" statement.
