09-13-2019 03:50 PM
Hello Everyone,
I am trying to figure out why vlan5 cannot access the internet. I get an ip from .2 dhcp pool and am able to ping default gateway 192.168.1.1 and 192.168.2.1
Any help is greatly appreciated!
Ryan
Router>en
Router#show run
Building configuration...
Current configuration : 2058 bytes
! Last configuration change at 22:16:52 UTC Fri Sep 13 2019
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool WiFi
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
ip dhcp pool TEST-vlan5
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2901/K9 sn FJC2005A0LS
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.1
description vlan5
encapsulation dot1Q 1 native
ip nat inside
interface GigabitEthernet0/1.2
description vlan5
encapsulation dot1Q 2
ip helper-address 192.168.1.1
ip nat inside
interface GigabitEthernet0/0/0
switchport access vlan 5
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
no ip address
interface Vlan5
ip address 192.168.2.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x
access-list 1 permit any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
Solved! Go to Solution.
09-13-2019 04:11 PM
09-13-2019 04:11 PM
09-13-2019 04:18 PM
Thank you so much for your help! It is working now!
