vlan id not seen by ESX host
michaelnolan
Hi there,
I was wondering if anyone has come across an issue whereby one vlan id i.e 10 is not seen by ESX host vnic's but the vnic in this vlan 10 can ping the default gateway on the vlan 10. The vnic's see the ip range but missing the vlan id of 10. A second vlan on this same switch can be seen correct by vnic's
Here is config of switch port facing the vnic.
interface GigabitEthernet0/16
switchport trunk allowed vlan 10,20
switchport mode trunk
spanning-tree portfast
I was wondering also that native vlan 20 defined on further upstream switch would this cause this issue. I don't thinks so.
Michael.
fb_webuser
Level 6
Level 6
Try configuring native vlan 20 on the trunk. also do not forget trunk encapsulation!!!!
Posted by WebUser Neeraj Jagga from Cisco Support Community App
I tried that but lost connectivity on vlan 20
SW1 - Blade sw
interface FastEthernet0/10
description ** uplink to enc2 sw4
end
Port        Mode         Encapsulation  Status        Native vlan
Fa0/10      on           802.1q         trunking      1
Blade switch - SW 1
interface GigabitEthernet0/17
switchport trunk allowed vlan 32,33,35,42,43,45,51-64,70-73,81,200
Gi0/17      on               802.1q         trunking      1
Switchport on vnic
switchport trunk allowed vlan 81,200
Gi0/16      on               802.1q         trunking      1
