VLAN INTERFACE 1750
ccnamonsun
Community Member
What is use of VLAN interface on cisco 1750 router.
Can we connect Vlan togather if yes then HOw Guide me
Georg Pauwen
with the use of VLAN interfaces, you can indeed use the 1750 router for inter-VLAN routing.
Check this link for a description on how to configure this:
Cisco 1751 Router Software Configuration Guide
Routing Between Virtual LANs Overview
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008008951a.html
HTH,
GP
My understanding was that the 1750 (and the 1720) do not support 802.1q trunking, whereas the 1721 & 1751 routers do support it.
I have tried to set this up previously and didn't have any luck with the 1750 or the 1720. I did look on CCO and the feature navigator informed me that the 1750 does not support 802.1q.
I would be pleased if either (1720 or 1750) router did as this will fix some issues I have with a customer.
Andy
