vlan interface down
DonnaJ
Level 3
Level 3
How do figure out why? I tryed no shut down, still down...
41-Switch-1#sh int vlan 3
Vlan3 is down, line protocol is down
Hardware is EtherSVI, address is 000a.f421.e800 (bia 000a.f421.e800)
Internet address is 10.7.41.210/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
20 Replies 20
Thanks for helping actually i was reading this part from book
There are no SVIs active on the MSFC-not even VLAN 1. Let's add an SVI for VLAN 20 and see what happens:
Code View: Scroll / Show All
MSFC-6509# conf t
Enter configuration commands, one per line. End with CNTL/Z.
MSFC-6509(config)# int vlan 20
MSFC-6509(config-if)# ip address 10.20.20.1 255.255.255.0
MSFC-6509(config-if)# no shut
MSFC-6509(config-if)# ^Z
MSFC-6509#
17w2d: %LINK-3-UPDOWN: Interface Vlan20, changed state to down
17w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed state to down
MSFC-6509#
MSFC-6509# sho ip int brief
Vlan20 10.20.20.1 YES manual down down
The SVI is now there, but it won't come up. The SVI will not come up unless there is an active port in the VLAN in layer two. I often forget this fact and, after adding the SVIs, go off to create my VLANs only to find that none of them will come up. To illustrate the point, I'll assign an IP address to the CatOS management interface SC0, and place it in VLAN 20. This will put an active device in the VLAN:
CatOS-6509: (enable) set int sc0 20 10.20.20.20 255.255.255.0
Interface sc0 vlan set, IP address and netmask set.
Now, with something active in VLAN 20, the VLAN 20 SVI comes up in the MSFC:
Vlan20 10.20.20.1 YES manual up up
Now i know that Sc0 management IP of Cat OS is assigned at switching side.and we can assign only 1 ip at switching side which is using CatOS right?
"Now i know that Sc0 management IP of Cat OS is assigned at switching side.and we can assign only 1 ip at switching side which is using CatOS right?"
Yes.
The other way to ensure that your vlan interfaces come up is if you have a L2 trunk to another switch and the vlan is allowed on this trunk. Then the interface would come up as well.
Jon
hi jon,
i have switch 6509 which on cat os side has
number of vlans with ip addresses???????????
so on cat os side is it ok to have no of vlans with ip addresses
Mahesh
If it is truly a Catalyst 6509 and running CatOS on the switch side, then I do not believe that you can put multiple IP addresses on multiple VLANs. Perhaps you can post some details from the switch so that we can see what you are talking about.
The only way that I know to put multiple IP addresses on multiple VLANs is either to be on the MSFC rather than the switch or to be running IOS code rather than CatOS.
Rick
Rick
thanks rick for reply
actually those ips were vlan names
i am ok
thanks once again
Mahesh
VLAN names makes much more sense. I am glad that you are ok.
Rick
Rick
