Vlan Interface force up
ghauptmann
Visitor
Hello
Is there a way to force a SVI Vlan Interface up if no physical link is connected.
Best regards
Gerhard
6 Replies 6
Richard Burts
Gerhard
Try configuring a trunk on the switch that includes that VLAN.
Ric
Rick
rsohi
Level 3
Level 3
Hi Gerhard, try the following commands:
int vlanXXX
vlan XXX
I have used this in the past and it tends to bring the vlan ints up.
regards,
Raj
cstep
Community Member
config terminal
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no autostate
no shutdown
interface Vlan2
no autostate
no shutdown
interface Vlan3
ip address 192.168.2.1 255.255.255.0
no autostate
no shutdown
int range FastEthernet0/1 - 8
switch access vlan 1
switch mode access
int range FastEthernet0/9 - 16
switch access vlan 2
switch mode access
int range FastEthernet0/17 - 24
switch access vlan 3
switch mode access
end
produces the following results with all ports unplugged.
What IOS version supports the autostate command?  I just loaded 15.0(2)SE IP base on a 3560v2 and this interface command is not available.
-Jeff
cadet alain
take a look here: http://blog.ioshints.info/2009/07/followup-vlan-interface-status.html
Regards.
Alain
mahmoodmkl
Level 11
Level 11
i think u have ti type it
