VLAN interface issue
rdquraishi
FG-Win-PC1
IP 20.0.10.1/24
Gateway 20.0.10.6
DNS 8.8.8.8
FG-LAN-SW1
vlan 10
interface Vlan10
ip address 20.0.10.6 255.255.255.0
no shut
interface Ethernet0/1
switchport mode access
switchport access vlan 10
interface Ethernet0/0
switchport mode trunk
FG-FW1
port3
Vlan10
IP 20.0.10.5/24
FG-Win-PC1- I can ping 20.0.10.6(SW INT Vlan10) and 20.0.10.5(FW INT Vlan10)
but for 8.8.8.8 reply from 20.0.10.6 destination host unreachable
FG-LAN-SW1- I can ping 20.0.10.5(FW INT Vlan10) and 20.0.10.1(PC1)
but for 8.8.8.8 packet is not forwarding over the trunk port
FG-FW1- I can ping 20.0.10.1(PC1), 20.0.10.6 (SW INT Vlan10) and 8.8.8.8
please suggest me on this when i am pinging google dns the traffic is not passing through the switch
12 Replies 12
M02@rt37
Hello @rdquraishi
On Windows PC configure Gateway with IP 20.0.10.5 and re test. Thanks.
I you want SW to be Gateway, ensure to add this command: ip default-gateway 20.0.10.5.
Best regards
On the switch there are 2 vlan 10 and 20 and both are connected to firewall port3 with vlan 10 and 20 , then how I can put single default ip as a gateway for both vlan.
I want to separate vlan traffic over the switch and firewall as well
PC1 IP 20.0.10.1 gateway 20.0.10.6 SW1 Vlan10 20.0.10.6 firewall(port3) Vlan10 20.0.10.5
PC2 IP 20.0.20.2 gateway 20.0.20.6 SW1 Vlan20 20.0.20.6 firewall(port3) 20.0.20.5
How I can separate the vlan traffic?
@rdquraishi
Configure Gateways on PCs with respective IP hosted by L3 equipement, i.e. the FW in your case
Best regards
I have configure interface vlan 10 and 20 which are the gateway for pc, when pining 8.8.8.8 from the pc traffic is getting droped on gateway
what routing do you have configured on the switch and on the firewall ? Post the running configs of the switch and the firewall...
post the output of 'sh run' so the entire configuration is visible.
rdquraishi_1-1708352976735.pngrdquraishi_2-1708352996416.pngrdquraishi_3-1708353065074.pngrdquraishi_4-1708353283432.png
FG-LAN-SW1#terminal length 0
FG-LAN-SW1#show running-config
Building configuration...
Current configuration : 1058 bytes
! Last configuration change at 14:30:23 UTC Mon Feb 19 2024
version 15.2
service compress-config
hostname FG-LAN-SW1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Ethernet0/2
switchport access vlan 20
interface Ethernet0/3
interface Vlan10
interface Vlan20
ip address 20.0.20.6 255.255.255.0
ip forward-protocol nd
ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
end
FG-LAN-SW1#show interfaces trunk
Port Mode Encapsulation Status Native vlan
Et0/0 on 802.1q trunking 1
Port Vlans allowed on trunk
Et0/0 1-4094
Port Vlans allowed and active in management domain
Et0/0 1,10,20
Port Vlans in spanning tree forwarding state and not pruned
Et0/0 1,10,20
FG-LAN-SW1#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
20.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 20.0.10.0/24 is directly connected, Vlan10
L 20.0.10.6/32 is directly connected, Vlan10
C 20.0.20.0/24 is directly connected, Vlan20
L 20.0.20.6/32 is directly connected, Vlan20
FG-LAN-SW1#
I agree with M02@rt37, the default gateways on both PCs should be the firewall IP addresses in this case, not the swith. PC1 should point to 20.0.10.5 and PC2 should point to 20.0.20.5, that should fix the issue with the PC external connectivity.
if i put default gateway 10.5 and 20.5 on pc that works, but i dont want to use firewall as gateway i have to put switch as gateway, what would be possible solution on this case
Ok np. In that case I would suggest creating a transit network between the switch and the firewall, say VLAN 30, and then you configure the switch port connected to the firewall in VLAN 30 in access mode, and finally you configure a default route on the switch pointing to the firewall as the default gateway "ip route 0.0.0.0 0.0.0.0 < the firewall interface in VLAN 30 >".
In that scenario the inter-VLAN routing will be managed by the switch, and only the traffic that will need to go out will hit the firewall.
