Vlan interface "unknown protocol drops"
Steve Coady
Hello
I have a satellite office that connects via VPN back to my Corporate office.
The VPN is terminated on an Cisco 891.
I have received complaints from the user's there that their Citrix session hangs on them. They can then reconnect the session and
find the session was still going as they started back where they left off. There are several pc's that experiewnce the same issue.
The Citrix server has been checked out. The PC's have been checked out and re-imaged just to make sure.
I see on the Vlan interfacfe on the 9891 there are alot of unknown protocol drops.
What does this mean and could it be the cause of the session hang?
Vlan10 is up, line protocol is up
  Hardware is EtherSVI, address is 4403.abcd.efgh (bia 4403.abcd.efgh)
  Internet address is 10.x.221.1/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not supported
  Last input 00:00:05, output never, output hang never
  Last clearing of "show interface" counters 22:43:53
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     218197 packets input, 33432444 bytes, 0 no buffer
     Received 6568 broadcasts (0 IP multicasts)
     189384 packets output, 79892307 bytes, 0 underruns
     0 output errors, 0 interface resets
     7433 unknown protocol drops
sMc
prcsdm001
The unknown protocol drops can be caused by DTP, CDP or LLDP protocols which are not enabled on your router. These is not a problem and you can ignore it. I would check the physical interface too and performance on the satellite connection.
Adam
prcsdm001
Adam
Adam
Thank you for the response.
sMc
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
If you're running Citrix across a VPN, that crosses the Internet (?), I would be first concerned about transient latency and/or packet drops.  I would also be concerned whether your VPN has been configured to avoid packet fragmentation.
