VLAN is being blocked
samador382
Hi there,
I have little experience with Cisco equipment. As of right now I am trying to connect (trunk I believe) two switches together. The main switch is a 3560 and the other is a catalyst 2950. Someone setup a VLAN on port 48 of the 3560. I want to connect a switch to that port so I can have multiple devices plugged in. First off, is this even possible? Secondly, if it is,how do I go about successfully connecting the two switches?
This is what I have done so far.
On switch 3560 (main switch) the VLAN is 30. (This was created by someone else)
I created VLAN 30 on the 2950 with the range of all ports (1-24) in that VLAN.
Then I set fa0/1 to trunk mode. When the line came back up I got this error.
21:34:39: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan i       d 30 on FastEthernet0/1 VLAN1.
21:34:39: %SPANTREE-2-BLOCK_PVID_PEER: Blocking FastEthernet0/1 on VLAN0030. Inc       onsistent peer vlan.
21:34:39: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/1 on VLAN0001. In       consistent local vlan.
MYSWITCH#
Again, I have no clue what this is and I would really appreciate some help.
Thanks for looking!
-SA
42 Replies 42
I ran this command and the laptop connected to directly to port 48 on the MAINSWITCH still does not have internet access. Do I need to put a default ip on the VLAN?
Thank you for taking the time,
-SA
Ok, sounds like you have a lot more work to do.  Here are a couple questions:
- were you told to use VLAN 30 as a test by someone who appropriately said VLAN 30 was usable.  If you were, can you ask if the main switch is L3 or L2 to a router-on-a-stick or other L3 gateway?
- send the output of a "show cdp nei" command from the main switch
- send the output of a "show ip int br | ex unass" from the main switch
Here is a little more info to better understand my environment.
That MAINSWITCH has a few VLANS on it already. The VLAN 30 was setup by a company that hosts some of our servers.
The VLAN 30 is what I want to use as a test environment. All other VLANS on this switch have internet access. When the guy setup the VLAN on that MAINSWITCH, he was supposed to ensure internet access was possible.
Unfortunately for me, this network has been inherited from a person who is no longer with the company, and the people who host some of our servers charge for everything. They charged us just to setup the VLAN in the first place. $100.
I should probably contact them and let them know it is not working. But they might want to charge since changes have been made to it. I will try anyway. However, for the sake of getting this running, I am pretty sure it is a Layer 2 Switch. Below is the show commands you asked for.
#show cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
XXXXXX Fas 0/45 124 T B I AIR-CAP26 Gig 0
MAINSWITCH
Gig 0/1 151 S I WS-C3560- Gig 0/3
#show ip int br | ex unass
Vlan2 XX.XX.XX.XX YES NVRAM up up
main switch 3560
show vtp stat
VTP Version                     : 2
Configuration Revision          : 15
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 15
VTP Operating Mode              : Client
VTP Domain Name                 : XXXXXXXXXX
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xF3 0x8D 0xCC 0xDF 0xD9 0x12 0xFF 0x22
Configuration last modified by 10.192.17.254 at 10-8-15 18:26:34
MAINSWITCH-Sw1#
MAINSWITCH-Sw1#
MAINSWITCH-Sw1#
MAINSWITCH-Sw1#
MAINSWITCH-Sw1#show vlan
VLAN Name                             Status    Ports
1    default                          active    Gi0/2, Gi0/3, Gi0/4
2    VOICE                            active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
                                                Fa0/25, Fa0/26, Fa0/27, Fa0/28
                                                Fa0/29, Fa0/30, Fa0/31, Fa0/32
                                                Fa0/33, Fa0/34, Fa0/35, Fa0/36
                                                Fa0/37, Fa0/38, Fa0/39, Fa0/40
                                                Fa0/41, Fa0/42, Fa0/43, Fa0/44
                                                Fa0/46, Fa0/47
3    DATA                             active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/46, Fa0/47
10   Lab                              active
12   VLAN0012                         active
14   VLAN0014                         active
16   WiFi                             active
17   Internal-Wireless                active
18   Guest-Wireless                   active
26   VLAN0026                         active
30   192.168.X.X-XX                  active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
10   enet  100010     1500  -      -      -        -    -        0      0
12   enet  100012     1500  -      -      -        -    -        0      0
14   enet  100014     1500  -      -      -        -    -        0      0
16   enet  100016     1500  -      -      -        -    -        0      0
17   enet  100017     1500  -      -      -        -    -        0      0
18   enet  100018     1500  -      -      -        -    -        0      0
26   enet  100026     1500  -      -      -        -    -        0      0
30   enet  100030     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Main switch
#show interfaces fa0/48
FastEthernet0/48 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0023.5d35.6e34 (bia 0023.5d35.6e34)
Description: Trunked Downlink to 2950 port 48
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 2 packets/sec
24082 packets input, 1771591 bytes, 0 no buffer
Received 22365 broadcasts (0 multicasts)
0 watchdog, 22080 multicast, 0 pause input
19567 packets output, 1464848 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
#show
#show int
#show run in
#show run interface fa0/48
Building configuration...
Current configuration : 104 bytes
interface FastEthernet0/48
description Trunked Downlink to 2950 port 48
switchport mode access
end
2nd switch 2950
show interfaces fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000d.bd01.f401 (bia 000d.bd01.f401)
Description: Trunked Uplink to 3560 Port 48
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
input flow-control is off, output flow-control is off
Last input 00:00:00, output 00:00:00, output hang never
Output queue :0/40 (size/max)
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
18756 packets input, 1401314 bytes, 0 no buffer
Received 16993 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 15947 multicast, 0 pause input
23927 packets output, 1753667 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
#sho
#show ru
#show run in
#show run interface fa0/1
Current configuration : 115 bytes
interface FastEthernet0/1
description Trunked Uplink to 3560 Port 48
switchport mode trunk
no ip address
end
Looks like configurations are still missing from the 3560. Can you re-paste that 3560 configurations provided into the 3560 (not 2950 switch).
This is what was returned after pasting the configuration
conf t
Enter configuration commands, one per line.  End with CNTL/Z.
MAINSWITCH-Sw1(config)#
MAINSWITCH-Sw1(config)#  interface FastEthernet0/48
MAINSWITCH-Sw1(config-if)#
MAINSWITCH-Sw1(config-if)#   shut
MAINSWITCH-Sw1(config-if)#   description Trunked Downlink to 2950 port $ion Trunked Downlink to 2950 port 4         8
MAINSWITCH-Sw1(config-if)#   no  auto qos voip cisco-phone
AutoQoS Error: AutoQoS not configured
MAINSWITCH-Sw1(config-if)#   no switchport access vlan 30
MAINSWITCH-Sw1(config-if)#   switchport encapsulation dot1q
% Invalid input detected at '^' marker.
MAINSWITCH-Sw1(config-if)#   switchport mode trunk
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
MAINSWITCH-Sw1(config-if)#   no switchport voice vlan 2
MAINSWITCH-Sw1(config-if)#   auto qos trust
MAINSWITCH-Sw1(config-if)#   no spanning-tree portfast
MAINSWITCH-Sw1(config-if)#   no shut
MAINSWITCH-Sw1(config-if)#  end
MAINSWITCH-Sw1#
MAINSWITCH-Sw1#  wr mem
9w3d: %SYS-5-CONFIG_I: Configured from console by admin on console
9w3d: %LINK-3-UPDOWN: Interface FastEthernet0/48, changed state to down[OK]
MAINSWITCH-Sw1#
9w3d: %LINK-3-UPDOWN: Interface FastEthernet0/48, changed state to up
9w3d: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/48 VLAN1.
9w3d: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/48 on VLAN0001. Inconsistent port type.
Send a show version from the 3560
What do you mean?
It appears that the 3560 rejected the "switchport encapsulation dot1q" command from the output you posted.  A "show version" command output may help me understand why.
Never mind I got it
show version
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 18:15 by nachen
Image text-base: 0x00003000, data-base: 0x01300000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
MAINSWITCH-Sw1 uptime is 9 weeks, 3 days, 1 hour, 42 minutes
System image file is "flash:c3560-ipservices-mz.122-35.SE5/c3560-ipservices-mz.122-35.SE5.bin"
cisco WS-C3560-48PS (PowerPC405) processor (revision R0) with 122880K/8184K bytes of memory.
Processor board ID FDO1238X2ZW
Last reset from power-on
5 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : XXXXXXXXXXXXXXXXXXXXXXX
Motherboard assembly number     : 73-9676-14
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO12380ELC
Power supply serial number      : DTN123147K0
Model revision number           : R0
Motherboard revision number     : A0
Model number                    : WS-C3560-48PS-E
System serial number            : XXXXXXXXX
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : FDO123801QE
Top Assembly Part Number        : 800-26378-04
Top Assembly Revision Number    : B0
Version ID                      : V06
CLEI Code Number                : COMU110ARA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   52     WS-C3560-48PS      12.2(35)SE5             C3560-IPSERVICES-M
Configuration register is 0xF
Ok, I see the issue.  Sorry, typing commands form memeory. Paste the following into your 3560:
   shut
   auto qos voip trust
   no shut
  end
  wr mem
After done, check on that switch to see if that port is trunking and forwarding VLANs 1 and 30 via the "show interface trunk" command.
OK. I pasted the configurations on both switches.
