VLAN issue
cisconoval
Hi All,
I am having an issue with VLAN intercommunication.
Server1(Source)
Switch Model: 6509
Vlan 100
Server2 (Destination)
Switch Model: 6509
VLAN 200
The problem is I couldn't ping the server2 from serve1 for some time. After few minutes its start pinging...like this the connectivity is losing intermittently...am afraid why its happening.
Can some one shed a light on this to get rid off.
Thanks in Adv
sam-lee
Can you paste your configuration? Did you check the port speed / duplex setting? Did you try another port or cable?
No enough information to determine the cause.
Rgds,
Sam
Sorry bcz of security policy I couldn't post the config details. Please guide me how & which config I have to chk.
The Server1 having the port setting as
FULL 100/10
The Server2 having the port setting as
FULL 1000 1000BaseSX
You have to make sure the switchport settings match the hardcoded port speeds of your servers , they cant be left as auto .
