Vlan layer 3 on Catalsyt 3650
Laurent-Urrutia
Hi Everyone,
Since two week, i work on new network infrastrucre.
With RGPD plan we need to isolate somes employee so i use vlan for that.
Overall the configuration work fine, but now i need to same similar setting with guest wifi.
It's little bit complex to explain but for sumary we have one catalyst 3560 for core network.
This switch is connected to our provider router (Orange), this network is allowed for guest wifi
Issue is :
My smartphone terminal Pda1 can't access to internet with SSID2 on  vlan210  , but i don't understand because the Pda0 is ok with the same ssid on the same vlan.
I suppose the problem is located between TOUSW03 and TOUSW02 but not sure
Schema :
Someone can help with this issue ?
2 Accepted Solutions
check if VLAN 210 is present on all switches (show vlan)...
Also,do your wireless clients get an IP address, and from where ?
Hi Georg Pauwen
You're right the vlan doesn't appear with the cli "Sh Vlan" on TOUSW03 and TOUSW04
I'm only refear to cli "sh running" i forgot to do :
Vlan 210
 name Guest
 no shutdown
Manu thank's for your tips ;)
Hi Georg Pauwen
Vlan 210
 name Guest
 no shutdown
Hello
Also try adding
int vlan 210
ip helper-address ( dhcp server)
res
paul
Kind Regards
Paul
