VLAN Mapping NXOS
yh-it
how can I do a simple vlan mapping on a nexus 9000 like I can do on a 9200L?
From the 9200L docs:
Device(config)# interface HundredGigE1/0/1
Device(config-if)# switchport mode trunk
Device(config-if)# switchport vlan mapping 10 20
Thanks!
7 Replies 7
DanielP211
Hello!
The configuration is quite similar (the only difference in the interface which will always be ethernetX/X):
interface ethernet1/1
switchport
BR
****Kindly rate all useful posts*****
Do you know if vlan mapping is possible on Nexus Version  7.0(3)I7(7)
Hardware is C9396PX
Allows the commands, but does not seem to work.
DanielP211
You also remember to enable the : switchport vlan mapping inside the interface configuration.
BR
yh-it
When I Do it this simple I get:
Warning: Eth1/42 : VLAN translation is only supported on vxlan enabled vlans
But we are not using vxlan at this moment.
BR
       - FYI https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs62393
    M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
yh-it
Thanks for your help! We are upgrading to 10.3!
