10-12-2025 06:28 AM
Hi All,
I have the following issue, and it would be great if you could provide some ideas on this.
we have voice handsets and currently connecting to 3rd party switch --->checkpoint fw --- connecting to LAN switch (sw2 Trusted network).
Recently we are replacing those voice handsets and required to create a new vlan with new dhcp scope for those new voice handsets.
My question is , how could you extend the broadcast domain across the fw to the 3rd party switch so that new handsets can communicate to our trusted network. My idea was more in to vlan mapping solution .
Phones does not have certificates and when the new voice handsets connects to the switchport as it requires to go through MAB initially and authorisation profile will allow the handset to connect to the certification server and then get a cert -->reboot and connect to the network..
Appreciate your advice on this
chaminda
10-12-2025 07:21 AM
Hello @Chaminda1912
VLAN mapping is supported by your Firewall model ?
10-12-2025 08:28 AM
yes..but needs to clarify with the 3rd party managed team if that's been approved to implement..
10-16-2025 02:52 AM
Have you check new vlan mapping configured end to end , 3rd party switch and firewall. Would you able to capture traffic ?
